Old 10-19-2020, 03:01 PM
gtojeff1967 gtojeff1967 is offline
Default 67 tilt steering column
I'm trying to change the turn signal switch in my column and i need to know how to take it apart or aleast get the outer tin off so i can get the wires thur, I tried to use a wire and pull it thur but no luck. I have the bigger nut and sleave and the upper bearing off but can not get the tin off?? Thanks for any help Jeff
Old 10-19-2020, 08:18 PM
Never tried to get one all apart. Removed plastic connector from wires. Pulled wires through and then reinstalled wire back into plug.
