Old 11-01-2020, 06:28 PM
Default &2 Lemans side rocker molding clips
I bought new rocker molding clips. The lowers seem to be not bent correctly to be able to grab the lower lip of molding and still be able to wrap under the rocker to screw it in place. Is this a normal issue with after market clips? I do have two originals and they seem to be much closer to be able to screw in place. I have three separate screw holes in lower rocker. Does this mean I need three long clips per side? The kit only came with four total (two per side).
