SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 11-14-2020, 12:23 AM
gto_bb gto_bb is offline
Default SMI Stage 2 Pontiac Quadrajet
New, unused stage 2 Pontiac Qjet from SMI.
Jet: 76
Rod: 46K
SEC: DA
Also comes with two 1/4" insulating gaskets from Quadrajetparts.com
It's in Lompoc, CA for local pickop.
$500 shipped to the 48 states.
Here's their writeup:
Part Number:
335010
Product Name:
Rochester 4BBL Quadrajet 800CFM for Buick & Oldsmobile
Description:
SMI - STAGE TWO - (800 CFM) ROCHESTER QUADRAJET
For use on Moderately Modified 350-400-425-455 engines with: Aftermarket Cam,
Aluminum Intake and Headers.
Our Price: $529.00 (does not include shipping or wait time)
Features
[LIST][*]Front Fuel Inlet[*]Intended for moderately modified street performance vehicles.[*]All circuits will be modified and tuned to match the specifications of your engine combination, Including:[*]Idle down tube(idle jet) and idle air bleed resized for smooth idle quality with performance camshafts.[*]CRO(channel restriction orifice) resized for crisp off-idle and part throttle response.[*]Main jet and metering rods selected for clean cruise mixture and strong part throttle response and acceleration.[*]Proper metering rod power piston spring selected to match engine vacuum characteristics[*]Secondary metering rods and hanger selected and high speed air bleeds resized for maxium full throttle horsepower and torque.[*]Select highest quality cores for best performance and reliability[*]Strip to bare metal, inspect for defects, then apply dichromate coating for brilliant gold finish.[*]Strip and cadmium plate all hardware, including throttle shafts, linkage, levers, spring and screws.[*]Install bushings in baseplate to eliminate any potential vacuum leaks at primary throttle shaft.[*]Install APT (ADUSTABLE PART THROTTLE) to allow adjustment of part throttle and cruise speed (steady throttle, 1800-4000 rpm) air/fuel mixture in seconds without any disassembly, tuning can be done while engine is running![*]Apply epoxy to main body casting plug to eliminate common "leak down" problem associated with Quadrajets.[*]Idle, transition, main, and high speed circuits modified to provided optimum fuel curve for YOUR engine[*]Assembled using the highest quality components, including:[*]New jets and metering rods.[*]High capacity accelerator pump featuring materials that are resistant to alcohol and other additive commonly found in today's fuel[*]Nitrophyl solid composite float that can't crack or sink.[*]Premium quality gaskets[*]High flow .130" needle and seat assembly.[*]New electric choke for cold starting and driveability.[*]New choke pull-off for clean, smooth warm-ups.
Old 11-29-2020, 07:15 PM
Price lowered, $450 shipped anywhere in US 48.
Old 01-02-2021, 11:03 PM
Vckline313 Vckline313 is offline
Still available?
Sent from my SM-N960U using Tapatalk
Old 02-09-2021, 03:55 PM
SOLD, thanks for looking.
