Old 11-17-2020, 11:37 PM
98 SNAKE EATER 98 SNAKE EATER is offline
Question Red or Black center caps for 70 T/A?
I've seen them both used and actually have a set of each, but how exactly did they option these out?
What would be considered correct for 70?
ID:	554199   Click image for larger version
Old 11-18-2020, 01:32 AM
Red
Old 11-18-2020, 09:14 AM
All my GM/PMD parts books show either one for 1970. So this is obviously a transition year probably based on if the car is an early build. Black is for 1967 to 1970 and red is for 1970 to 1972.
Old 11-18-2020, 09:19 AM
You’re correct and the Trans Am being a later car would be red .I don’t ever remember seeing a 70 TA with black center caps but I didn’t see them all
The Following User Says Thank You to Tellyshavilli For This Useful Post:
Old 11-18-2020, 09:31 AM
I forgot that that gen F body was a late version. You've owned the cars, I only own the parts and the books.
Old 11-18-2020, 12:09 PM
72projectbird's Avatar
My 03C 70 has red.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-18-2020, 01:19 PM
Formulabruce's Avatar
Jan and Feb show cars ( Detroit) and the Daytona race parade cars had black. They are only ones I have ever seen black from factory. Goodyear tires were used more than most think as well.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 11-18-2020, 02:29 PM
Red is correct.... Black looks better IMO
Old 11-18-2020, 11:30 PM
Agreed.
Old 12-03-2020, 12:16 PM
napster's Avatar
napster napster is offline
I seem to recall from a long time ago someone here on the board posted the change from black to red took place in December, 1969. There was a specific date in the month mentioned as well. I just can't remember the actual date or the posters name.
I have a 1970 GTO made in the third week of December, 1969 and it has red center caps.
The 1970 T/A in the stable was made in May, 1970. It has red center caps.
Old 12-03-2020, 02:22 PM
unruhjonny's Avatar
the 1970 model year was when the caps changed;
At the start of the model year, black caps were used, and the general consensus is that by January 1970 red caps were being used exclusively.
To answer the original question;
For 1970 Firebirds red caps are correct, and black caps are incorrect.
Keep in mind that at the time called "1970+", because 69 model year cars were being built through to November(?) 1969)
1970 Formula 400
