Old 11-29-2020, 10:26 PM
Hotrodjohn71 Hotrodjohn71 is offline
Default Oil filter housing bypass mechanism.
Group, my 65 Pontiac 326 oil filter housing has a bypass system. The spring doesn't seem very strong and the keeper does not seem heavy duty. Help me understand this.
Isn't oil through the filter under full oil pump pressure? And doesnt a filter have it's own built in bypass mechanism? I can't see that spring and disc in the housing holding much pressure. Thanks
ID:	555034   Click image for larger version
ID:	555035   Click image for larger version
Old 11-30-2020, 06:23 AM
Kenth's Avatar
Kenth Kenth is offline
Itīs an engine safety device.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-30-2020, 11:11 AM
Sirrotica's Avatar
A correct Pontiac oil filter does not have a bypass valve incorporated into the oil filter. Many other brands do have a bypass incorporated into the filter, Pontiac however, does not.
Pontiac engineers choose to build the bypass into the oil filter adapter, rather than incorporate it into the oil filter itself. The purpose is to not allow the hydraulic pressure to damage the filter element by tearing it, or collapsing it in a situation of thick oil upon cold startup, or a nearly blocked filter element due to neglect.
The spring and the disc in the filter housing only reacts to pressure differential between the pressure of the pump side of the filter element and the downstream side, kind of an equalizing valve to operate when there is too much pressure differential. It's not meant to stand the entire pressure of the system, and is not engineered to do so.
It's a safety valve, as has been already stated so the filter element isn't collapsed due to hydraulic pressure differential between the opposite sides of the filter element. There are some people that block this valve in an effort to make 100% of the oil travel through the filter element. The risk is that the element will tear, dumping all the accumulated trash from one side of the element into the engine. Not something I would want to happen inside of one of my own engines, I've never blocked the bypass valve in any of my race, or street engines.
Unless someone dissected every one of their oil filters upon removal, you would never know the filter element had ruptured. If someone wants to have the oil filtered to a higher standard, a by pass oil filter can be used in addition to the standard issue factory element. It will keep the oil much cleaner than the 30-40 micron standard issue filter does as they efficiently filter to the 5 micron range. This adds to oil, as well as engine longevity.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-30-2020, 12:09 PM
Thank you. I understand now. It's a pressure differential valve rather than a simple pressure relief valve. I like it and will keep it as intended.
Old 12-01-2020, 08:47 PM
68azbird 68azbird is offline
just use a good quality filter
It is easier to fool a man than it is to convince he has been fooled
The Following User Says Thank You to 68azbird For This Useful Post:
Old 05-12-2023, 09:40 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default spring retainer correct?
In the first pic in the first post: I was wondering if the metal retainer arm that holds the spring in place is installed correctly? I saw a pic in another thread and the metal retainer arm was installed flipped over. Just curious if it matters?
1970 T/A
The Following User Says Thank You to dpoltzer For This Useful Post:
Old 05-12-2023, 09:51 PM
Definitely it does matter.
The dimple pressed into the spring retainer is there to locate the spring, the dome of the dimple should face the spring.
Old 05-12-2023, 10:13 PM
dpoltzer's Avatar
Default Makes sense!
That does make sense B-man. Thank you.
1970 T/A
