Old 12-04-2020, 04:10 PM
allenga allenga is offline
Default Better Steering Box than Lares
Hi Guys, is there a better factory style steering box that Lares. I am pulling one out already for leaks after 4 months. Also, there was slop in the gears when the steering wheel was centered. Don't want a modern super tight box. Want the car to drive as it was. Think it was 2 1/2 lock to lock I think. Thanks!
Old 12-04-2020, 08:02 PM
RH68 RH68 is offline
Borgeson makes a brand new box.
Old 12-04-2020, 09:38 PM
I don't know how to describe it. This Lares box is geared differently. Its still like 2 1/2 lock to lock but it seems quick ratio right from center. That is not what my prior, original steering box with 53,000 miles felt like. My original box was easer to turn.
Old 12-04-2020, 09:52 PM
64speed's Avatar
64speed 64speed is offline
The Borgeson box is superior but if you’re stuck on Lares then RockAuto sells them. The Borgeson box is only 450. It is 2 turns lock to lock and is what you describe
The Following User Says Thank You to 64speed For This Useful Post:
Old 12-04-2020, 09:53 PM
I think I just found the answer to my question.
https://leepowersteering.com/pages/s...feel-explained
Old 12-05-2020, 02:41 PM
Formula8's Avatar
Formula8 Formula8 is offline
I swapped out my original box with a third gen Z28 box I had laying around. Other than an incredible amount of leaking from the Lee steering hose adapters, it was fairly decent. To stop the leak, I replaced the hoses and ordered a "WS6" box from Rock Auto and it absolutely sucks.....I am pretty sure it is slower than the Z28 box and has zero road feel but doesn't leak.
I plan to replace it with and original WS6 box that I verified the car it came off of and if that doesn't work, I will replace it with the Borgeson box over the winter. Here is a link to a review: https://nastyz28.com/threads/finally...ng-box.324423/
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
The Following User Says Thank You to Formula8 For This Useful Post:
Old 12-05-2020, 02:54 PM
Colin70TA Colin70TA is offline
I have the Borgeson one in my 70 TA, hands down night and day difference, highly recommended it!
Sent from my SM-A530W using Tapatalk
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-(
The Following User Says Thank You to Colin70TA For This Useful Post:
Old 12-05-2020, 10:22 PM
Thank you Colin. What do you like about it.
Old 12-05-2020, 10:24 PM
The biggest difference is there in no dead on center, which gives you a ton more confidence driving. My dad and brother liked it so much they bought them for their 2nd gens as well, its well worth the money.
Old 12-05-2020, 10:28 PM
Yes, I have talked to Lares tech support several times. They don't get or want to admit what I am talking about. Lots of dead space on center, little power assist. :-(
Old 12-06-2020, 12:25 AM
70GS455 70GS455 is offline
Hector Carillo (Carhex) sells rebuilt fast ratio boxes
Sent from my SM-G973U using Tapatalk
The Following User Says Thank You to 70GS455 For This Useful Post:
