Old 12-20-2020, 04:19 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default New Hydraulic Roller Lifter option - Arrow Injuneering / Sealed Power
Interesting new hydraulic roller lifter option for traditional Pontiac V8. Claims “Made in USA”, and under $300 (listed at $295) for set of 16.
https://pontiacspeedshop.com/sealed-...0UuhtqBeeFyAJs
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 12-20-2020, 04:28 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Ad says you need their Hydraullic roller retaining system. But I couldnt find that on their website. Wonder how much that is or how it works.
Old 12-20-2020, 04:57 PM
tom s tom s is offline
Looks like they have been machined for something like a dogbone?LS lifters?Tom
Old 12-20-2020, 05:01 PM
RocktimusPryme's Avatar
I saw it on facebook. They said availability of the retaining system is early 2021, and that the package should be cheaper than other retrofit roller lifter setups.
Im curious if the lifters are purpose made or if they are off the shelf SBF or something.
I like it. Ive never been happy with the noise of my comps.
Old 12-20-2020, 05:16 PM
Anti-rotation system comments from Arrow Injuneering:
“We are putting a system we have used since the '80s into production. It's so simple and easy to install that once you see it you won't believe the "Injunuity" of Arrow Injuneering! Coming Early 2021!”
Matt
70 GTO 400 4-speed
Old 12-20-2020, 06:07 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Aren't they the guys that were bring several new cylinder head options to market?
Go fast, see Elvis!
Old 12-21-2020, 08:21 AM
Cliff R's Avatar
Cliff R Cliff R is offline
It will be a really nice upgrade if they can come up with a retention/guide system that's pretty much a "drop-in" and allow the use of those style lifters in lieu of the type that require a link-bar.....IMHO.....
Old 12-21-2020, 10:49 AM
JMHO,I started running roller lifters about 1964 and linkbars have never been a issue for me!Tom
Old 12-21-2020, 11:21 AM
Formulajones's Avatar
I don't mind the retrofit stuff and have never had a problem with what's offered on the market with our Pontiacs, or any other brand engine.
Interesting that people are trying to come up with new ideas, especially for a Pontiac, but I really don't have a need to try it at this point.
https://youtu.be/XqEydRRRwqE
Old 12-21-2020, 04:05 PM
Dragncar Dragncar is offline
Looks like Randy Repp. He is a good dude. Pontiac to the core.
Old 12-21-2020, 05:56 PM
firechicken's Avatar
firechicken firechicken is offline
I like the idea of these lifters but it seems kinda silly to have them advertised for sale with no way of keeping them from rotating yet.
Old 12-21-2020, 07:22 PM
Cliff R's Avatar
In theory they shouldn't rotate as they are two flat surfaces one turning the other, but we all know that it's not a perfect World and you'd better wait for the associated parts to keep them lined up correctly!......LOL...
Old 12-22-2020, 12:19 AM
If plans work out I intend to move to a HR cam and may well give these a shot, pending the anti-rotation system.
Matt
70 GTO 400 4-speed
Old 12-22-2020, 02:23 PM
adynes's Avatar
adynes adynes is offline
I wonder if they got Sealed Power to make these with pontiac specific oil band location, or if they are just the standard sbc ht2148. The picture looks like the sbc lifter, but hard to tell. When I measured up an ht2148 a few years ago it looked like there would be a certain lobe lift you can't exceed or the band will come out the bottom of the lifter bore.
Old 12-22-2020, 06:07 PM
dmac dmac is offline
I've always wondered why non-round shaped lifters or lifters with a keyway that would fit in a groove aren't made, with the lifter bore machined to accept a non-round lifter that wouldn't be able to rotate.
Old 12-22-2020, 06:18 PM
Old 12-22-2020, 09:15 PM
Guys!Again,most of the issue with roller lifters have been with virtually ALL makes of hyd roller lifters.Only solid lifter issues for the most part have been in lack of maintenance and most in street applications!The link bars are NOT a real issue.Tom
Old 12-23-2020, 11:12 AM
takid455 takid455 is offline
Send a message via AIM to takid455
Food for thought. These look similar in design to GM LS lifters that use the plastic bucket retainers. Those are removed in favor of tie bar lifters due to rotation even with the buckets. This occurs with aggressive cam profiles along with typical engine heat softening the plastic. Seen it first hand. Only takes a few seconds to warrant a new cam. If the retainer for these is plastic, I would shy away.
Old 12-23-2020, 01:35 PM
I am finding very hard to believe GM would make these for 20+ years and this "issue" would happen and it would not be well known:
Do you have any evidence?
Old 12-23-2020, 04:33 PM
62posbonny 62posbonny is offline
My other car has a warmed up 6.0 LS in it. 95% of the guys in the LS world are still using the stock lifter buckets with streetable cams. In the LS world that's any cam with under .620 lift and some running up to 240's/250's duration. There are certainly guys running linkbar setups, but most are pushing wild lift/duration cams and spinning well beyond 7,000rpm. If this setup ends up working as well as the GM LS design I'd gladly throw a set in my car with a mid-high .500 lift cam turning less than 6000rpm without any concern.
