SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 01-03-2021, 12:10 PM
AIR RAM AIR RAM is offline
Default FS - Butler Performance PRO 80psi Oil Pump BPI-M54F-PRO *NEW*
I have a brand new, never used, never installed Butler Performance PRO 80psi Oil Pump BPI-M54F-PRO for sale. I am selling because I decided to run a different oil pump.
Asking $159.95 + Shipping. I'm fairly sure I can fit it into a USPS Medium Flat Rate box which is only $13.00. Its ready to ship!
Video Details
https://youtu.be/72Umb_fP1Rc
Purchase Now using Credit card or Pay Pal.
http://airram.com/product.php?catego...productid=1870
From the Butler Website:
"This oil pump is a Butler Performance exclusive! This pump has been completely remachined, blueprinted and tested to be what we feel is one of the best Pontiac oil pumps on the market. We now also offer this same PRO pump in a 60-65 psi version for the those of you that want a high quality oil pump but have a milder combo that doesn't require 80+ psi of pressure- See part# BPI-M54DS-PRO for the 60-65 psi version. Both include:
anti-gall/ anti-cavitation dimples in bottom of both gears
Extra thick diamond lapped .250" oil pump plate
Tops of Gears machined with 360 degree oil grooves to prevent galling against plate
Drive shaft bore supplied with oil groove/ micro polished drive shaft
Pump gear pedestal pads diamond lapped and supplied with oil groove
Idler gear honed and oil weep hole added
Gasket surface diamond lapped
Bypass ball and sealing surface machined/blueprinted
Bypass spring tested/blueprinted
Copper gasket included
Flow chart included
Includes extra shim for adjusting spring pressure 5-10 lbs
Features oil retention points on each tooth to prevent galling on the plate
Due to the thickness of the plate on the Pro pumps, when using a pickup with a mounting tab, a slight modification of the tab may be necessary. This can easily be done by bending the tab up and elongating the mounting hole.
We recommend a 1/8-1/4" oil pan to pickup clearance. Must be checked with all pumps and pickups regardless of oil pan."
https://butlerperformance.com/i-2445...tegory:1234738
If you have any questions or concerns please feel free to contact me.
SPEED SAFE, NICK
Name:	Butler 80psi Oil Pump.jpg
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 01-07-2021, 09:06 AM
Still available, New ready to ship. This pump is Brand new.
Also Shipping from Butler is a couple bucks more expensive so this pump would be a little cheaper after shipping.
SPEED SAFE, NICK
Old 01-11-2021, 05:20 PM
Still available, This pump is Brand New ready to ship!!!
SPEED SAFE, NICK
Old 01-15-2021, 01:15 PM
SPEED SAFE, NICK
Old 01-20-2021, 09:18 AM
SPEED SAFE, NICK
Old 01-26-2021, 12:59 PM
SPEED SAFE, NICK
Old 01-30-2021, 04:16 PM
SPEED SAFE, NICK
Old 02-03-2021, 08:17 AM
Looking for a good home, This pump is Brand New ready to ship!!!
YouTube Video Details - A video is so much better than pictures alone!!!
I can accept most major Credit cards or Pay Pal what ever you prefer.
SPEED SAFE, NICK
Old 02-08-2021, 04:34 PM
SPEED SAFE, NICK
Old 02-15-2021, 09:37 AM
SPEED SAFE, NICK
Old 02-19-2021, 01:54 AM
Lowered price to $149.00 + shipping.
http://www.airram.com/product.php?ca...chquery=butler
SPEED SAFE, NICK
Old 02-26-2021, 01:57 PM
SPEED SAFE, NICK
Old 02-28-2021, 05:08 PM
SOLD!!!
Thank you for looking!
SPEED SAFE, NICK
