Old 01-08-2021, 08:40 PM
Default 68-72 Safe-T-Track with 2.93 or 3.08
Looking for a complete posi rear diff, bolt-in preferred. I’m in Central CA so could pick it up just about anywhere in California. We could discuss shipping options too. Thanks, Will
Old 06-06-2021, 12:11 PM
Still looking
Old 06-08-2021, 05:18 PM
acgwinn acgwinn is offline
Where are you located?
Old 06-09-2021, 12:26 PM
I’m located in Central California.
Old 06-23-2021, 01:49 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Auburn does make a new posi diff for that series if you have a clean good open 2.93 3.08 3.23 ...
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 10-30-2022, 11:09 PM
Still looking. Also would consider 2.93, 3.08 or 3.23 non-posi complete differential.
Old 10-31-2022, 09:55 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
I’ve got a complete 8.5 open 2.93 gears in KS
Old 11-01-2022, 08:57 AM
AG's Avatar
AG AG is offline
I have a 1971 3.08 posi (code BE) from a GP with a 4-pin posi. Same rear for an A-body except it has a 4-pin posi rather than a 2-pin. I'm in NH so shipping would be expensive.
Old 11-01-2022, 12:07 PM
That sounds nice AG, unfortunately completely on the other side of the country from you. Gives me hope there may be one closer.
Old 11-01-2022, 12:36 PM
Thanks for the reply 63 Longtop, will keep it in mind but just checked summit and a posi unit for this is close to $700.
Old 11-01-2022, 09:18 PM
poncho-mike poncho-mike is online now
It's a shame you're on the opposite side of the country. I have a couple of 2.93 heavy duty limited slip axles out of 1969 and 1970 Grand Prixs. I like finding limited slips in GPs because I am pretty sure every one I've seen has been a 4-pinion posi. I know the 3.23 limited slips have been 4-pinion, whereas the GTO versions were 2-pinion.
Old 11-02-2022, 01:37 PM
Hey Poncho Mike,
Would you be willing to sell one of those 2.93 ring and pinion and 4 pinion posi assemblies? I’m sure it weighs close to 50 pounds but I can get a pretty good deal on shipping and source a BOP 8.2 housing and axles more local to me. Understandable if you don’t want to cannabalize your set-up. Thanks for responding to the want-ad. I tried sending you a PM but your box is full.
Old 11-03-2022, 02:45 PM
Mr. G Mr. G is offline
I have a complete 2:72 safe-t- track removed from a 1971 LeMans if that does you any good. Location near Reno.
Old 11-03-2022, 04:19 PM
Mr. G, 2.73s are a little too tall but thank you.
