Old 01-23-2021, 05:32 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
Default 65 GTO drivers valve cover
Will trade a 66 valve cover if interested, otherwise let me know how much, thanks!
Old 08-25-2021, 04:58 PM
tallrandyb's Avatar
Every place sells a set online and I'm not traveling to swap meets, I just need one and have one I could trade, or just pay for.
Old 08-25-2021, 10:30 PM
BOB VIDAN BOB VIDAN is offline
How nice do you want?
Practicing social distancing for 65+ years
Old 08-26-2021, 04:52 PM
tallrandyb's Avatar
No nicks/dings with nice shine. Doesn't have to look brand new but I like popping the hood and having everything look great/correct (as reasonable).
If you have a pic and you want to DM me that would be great, thanks, or just post here.
Old 08-28-2021, 02:19 PM
Will have to pass, are rougher then I remembered.
Old 08-28-2021, 04:44 PM
tallrandyb's Avatar
No problem, thanks though!
Old 12-03-2021, 08:39 PM
Pecosbill's Avatar
I have a pair of 64's which I believe are the same (if not, please correct me). They're at ranch and I won't be going back up there until Tuesday, but if you're still looking let me know.
Bill
Pecosbill
Old 12-04-2021, 08:29 AM
tallrandyb's Avatar
Drivers side is same which is what I need. Passenger side has filler pipe for 64 but has the screw-on breather for 65. I just need the drivers. Thanks!
Old 12-04-2021, 10:43 AM
Pecosbill's Avatar
I found a pic of when covers were on old motor. Look and see if you can tell from pics if that is what you need. I don’t think they are dented but they should be rechromed to look right on a nice restoration.
ID:	579100   Click image for larger version
Pecosbill
Old 12-04-2021, 11:55 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
This photo is just for identification reasons.
A pair of Original 1965 oriented valve covers.
Most of 1964 and all of 1965 had a rubber plug on the LH valve cover as shown below.
Old 12-04-2021, 02:03 PM
Pecosbill's Avatar
I do not believe that there is any hole at all in the driver's side cover. I'm not sure what year model these covers are from.
Pecosbill
Old 12-04-2021, 03:04 PM
A nice original pair of ‘64 GTO valve covers for reference.
Old 12-04-2021, 03:39 PM
389 389 is offline
The engine builders usually have two breathers on the passenger side valve cover, nothing on the driver's side.
Old 12-04-2021, 07:52 PM
60sstuff's Avatar
I’m not sure what post #11 is referring to, but “ALL” 1965 GTO’s plus Lemans had a solid plug or grommet in the LH valve cover.
How the Factory assembly was done.
Solid rubber plug if sold new in 49 states.
Rubber grommet to accommodate air cleaner breather tube if sold new in California as part of the 614 option.
1) First photo is a 1965 magazine test article on a ‘65 GTO.
2) Scott Tiemann Original family owned restored ‘65.
3) Original Unrestored Survivor ‘65.
4) An Original ‘65 Lemans 326.
5) An Original owner ‘65 with the 614 option.
PS, Ames catalog seems to be aware of the HOLE on the LH valve cover and PLUG on pages 186-187.
ID:	579130   Click image for larger version
ID:	579131   Click image for larger version
ID:	579132   Click image for larger version
ID:	579133   Click image for larger version
Old 12-04-2021, 09:18 PM
Pecosbill's Avatar
Originally Posted by 60sstuff View Post
I’m not sure what post #11 is referring to, .
Post #11 is referring to the pair of covers I have and was checking to see if they were what he was looking for. As I stated, I don’t know what year they are from, but bman’s post would seem to indicate that they are from a 64. See posts #7 and #9.
Pecosbill
