Old 01-27-2021, 04:13 PM
sportylemans sportylemans is offline
Default Muffler selection replacing imco t906
Getting a new exhaust Putin the 71 lemans, 350 with manifolds. Just about stock except for a summit 2800 cam and electronic distributor.
Currently has 14” IMCO T-906 mufflers that have so much drone while cruising, I keep thinking my ears are going to bleed. Started looking at the dynomax super turbo and because of the offset it’s Eather the 17732 (14”)or 14479 (20”) for that brand
Keeping the same diameter exhaust (2.25”) when replaced and just want to lesson the drone to hear some music.
Any recommendations on these 2 or another brand?
Old 01-27-2021, 05:51 PM
Formulajones's Avatar
My favorite muffler brand to use. I recommend the 20" case.
https://youtu.be/XqEydRRRwqE
Old 01-27-2021, 06:24 PM
leeklm's Avatar
leeklm leeklm is offline
X2. You will be very happy with the 20" case super turbo
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 01-27-2021, 06:25 PM
OG68 OG68 is offline
I had a pair of the 20" mufflers on my SS El Camino with headers and an otherwise stock exhaust system.. Fairly quiet until 2500 RPM when they really opened up. No drone at any time.
2007 Cadillac SRX
Old 01-27-2021, 08:44 PM
Thanks everybody, y’all made the decision easy.
