Old 02-04-2021, 05:06 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Newest ideas for coolant holes in aftermarket blocks
So what is the newest thoughts for what coolant holes and where on aftermarket blocks not dry deck running? Just copy factory size and locations?
Skip Fix
Old 02-04-2021, 05:25 PM
cgeise's Avatar
cgeise cgeise is offline
some of the original are way close when you go to bigger bore
Old 02-04-2021, 06:10 PM
Steve C. Steve C. is offline
Cometic has a MLS gasket available with small water holes.
Old information here:
chiefbigb chiefbigb is offline
I think the butlers make a larger bore gasket . Believe it locates the holes away from the bore some.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 02-04-2021, 06:27 PM
When we did my IA2 block for my street 505 engine Pontiac Dude furnished us with details where he drilled his blocks that used revised smaller cooling holes. Among other considerations, as suggested above away from the bore some.
Based on it we had Cometic make a custom gasket for us. It has specific part number assigned to the design by Cometic with a 4.380" bore / .040" thick.
Old 02-04-2021, 07:09 PM
A fwiw, regarding the special gaskets I mentioned in post #3 above I was told they have 20 percent smaller cooling holes in certain locations.
Old 02-04-2021, 08:53 PM
Skip Fix's Avatar
Steve I think I got the same from Dude.
Bore is going to probably be 4.350, but way smaller as delivered on the aluminum IA. Not sure if they are thicker around than the iron blocks since they have the sleeve and the aluminum support or it. or any siamesing in there, like where the "421" hole is.
Cometics can make them with custom sized holes. Butler's holes are "proprietary" and they will not sell his gasket pattern to someone else.
Skip Fix
Old 02-04-2021, 09:54 PM
Half-Inch Stud's Avatar
Just drilled my 48s for coolant between the center exhausts. Block has been done awhile ago.
