Old 02-20-2021, 01:28 PM
theblurrrr theblurrrr is offline
Default 67 B-body wiper refills 18"
I'm looking for some definitive information to replace the wiper refills on my 67 Catalina. They are overlapping, articulating 18" Trico blade/arm assemblies. They are original equipment.
I have two cars, both made at the Southgate, California plant in late 1966. Both have exactly the same wiper setup with the double articulating arms. Both blades appear to be integral to the arm assembly; only the refill is replaceable.
Does anyone have information on an exact replacement refill part number or source?
Thanks!!!
Real cars don't sound like weedeaters!
1994 Buick Roadmaster Estate Wagon
1992 Corvette Coupe
1996 Cadillac Fleetwood Brougham V4P
1989 Chevrolet K1500 Diesel
1967 Pontiac Grand Prix Hardtop
1967 Pontiac 2+2 Hardtop
1956 Cadillac Series 62 Sedan
Old 02-20-2021, 02:10 PM
77 TRASHCAN's Avatar
The engine old Anco refill part number was/is 11-18. I don’t know if they are being made anymore, though. I need some for my 77 TA, also. My wiper blades fit under the hood ( hidden wipers). It’s a tight fit, and most wipers are too tall. I have no interest in using these later model lates!
Shut it off
Shut it off
Old 02-21-2021, 08:33 PM
scottydl scottydl is offline
Same wiper refills needed here for my 69 Executive, identical style you have both described. If anyone finds them, please let us know.
Old 02-21-2021, 11:05 PM
Anco has a website. Contacting them is not out of the question. I’d like to have a set of refills and some spares, I just don’t need them in a big hurry, at the moment.
Shut it off
Shut it off
Old 02-22-2021, 09:58 PM
stevep's Avatar
stevep stevep is offline
Sometimes Rock Auto and Walmart have them
Old 03-19-2021, 10:46 AM
I found a Texaco Refill set NIB marked "RF-18". They work on my 67 2+2.
1992 Corvette Coupe
Old 03-19-2021, 10:47 PM
Did you find those retail someplace? Or only being sold online?
I found these Trico 18" refills at Classic Industries... no photo and only 70's models are listed, but it seems like they would be the correct item?
Old 03-19-2021, 11:15 PM
They should work. Different brands had different ways of installing. I order wiper blades for the buses I work on through the local (Freightliner) bus dealer. I checked with them a couple years back about the Anco 11-18 refills, that number was it in their system....
Point: the boxes (10 wiper blades per case/box) l. The Anco part number in the box, listed the Anco number, but in fine print l, said made by Trico Industries. Sooo Trico might be THE source of 18 inch refills......maybe.....
Shut it off
Shut it off
Old 03-19-2021, 11:36 PM
stuta stuta is offline
I'm glad I stumbled upon this thread , as I just purchased a 67 Ventura hardtop. I'd like to pick up some blades for her too.
Thanks for the suggestions
Old 03-20-2021, 01:00 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
I used those in my '67 years ago, they worked just fine.
The biggest problem you'll find is the tension on the blades themselves is going bad after 50+ years. The "springiness" if you will. This means they don't wipe clean as well as they did when new.
