Old 03-05-2021, 09:39 PM
bober bober is offline
Default Where to find a 70 T/A Tail panel filler
I'm trying to help a friend restore a 70 TA and he cannot find a tail panel filler replacement for it . AMD makes 1 for a 74-78 but no listing for the 70 . Any one know of a place to get this ? Thanks
Old 03-05-2021, 11:09 PM
You could post in the Parts Wanted section on this site.
Or they show up on ebay occasionally, such as this one:
https://www.ebay.com/itm/1970-1973-F...wAAOSwzQxgOx3a
The Parts Place sells a repro, but I don't know how good it is.
Old 03-06-2021, 12:15 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
I believe there is one posted here as of today?
Parts for sale. Seller grtd777?
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 03-06-2021, 12:54 PM
Not certain this what you're looking for but I believe the link Ifdsteve was referring to from grd777 was:
https://forums.maxperformanceinc.com...d.php?t=839519
googled it and located these two from Firebird Central
Rear Body Tail Light Finish Filler Panel
https://www.firebirdcentral.com/1970...p/she-2523.htm
Rear Body Tail Light Metal Panel
https://www.firebirdcentral.com/1970.../she-2522c.htm
No knowledge of the fit or quality though
Old 03-06-2021, 04:17 PM
Formulabruce's Avatar
The parts place unit has ZERO radius on the top that curves to trunk, the mounting carriage bolts are wobbly and not in correct locations for exact fit. The "P O N T I A C " letter holes are not consistent at best. Lots of work to get this part to work. Figure a full 8 hours anyway and multiple on and off testing on a straight car
Old 03-06-2021, 05:02 PM
78w72 78w72 is offline
isnt that the case with the majority of parts from PP??
Old 03-06-2021, 06:17 PM
While probably true, I decided to comment on this subject part and thread based on my own experience with these tail panels.
The Following 2 Users Say Thank You to Formulabruce For This Useful Post:
Old 03-07-2021, 05:56 PM
FASTASSBIRD FASTASSBIRD is offline
I got a real nice one, but shipping typically makes it cost prohibitive
Old 03-07-2021, 10:01 PM
Possible to see a picture ?
Old 03-07-2021, 10:31 PM
sure, but the last time i tried and ship one to MI it was like 225 bucks due to length
Old 03-07-2021, 10:37 PM
Ok , hold on until I get some more info from him . I don't think this is the same part he needs by your description .
Old 03-07-2021, 10:42 PM
Everyone is describing the fiberglass tail panel that the lock passes through and the PONTIAC letters attach to. its about 5 foot long (width of the car)
Old 03-07-2021, 10:48 PM
HE's replacing inner outer Q/panel and there's a smaller piece he wasn't aware of needing also to go along with that or he found more rust but he showed me a pic of a part that looked like a rather small part . He found one for a 74 -78 but he needs a 70 . Thanks for you help .
Old 03-08-2021, 10:44 AM
This part you refer to goes between the metal tail panel and the tail light area to rear quarter. Its about 10 " long and 4-5" wide. It is NOT available for 70-73 Firebirds. Many places sell it as such, but it is, in fact , a Camaro part. Better to make one than try to use it.
Old 03-08-2021, 12:22 PM
sd7369's Avatar
sd7369 sd7369 is offline
When I was working with Goodmark on the quarterpanels back in 2013, I pleaded with the community for a pair of used filler in any condition (even one side would ahve been sufficient) in an effort to make this package complete with the trunk extensions, quarters and tailpanel. Alas I did not receive a single response. Consequently, these are not made by any company as of today that I am aware of.
Old 03-08-2021, 01:55 PM
Tremendous thanks again for your dedication on getting the rear sheetmetal produced for these cars.
Never saw the request for the filler pieces - but i don't have a 70-73 parts car anyway.
However there is a clapped out-parted out-bone skeleton of a 70 Bird about 20 miles away from me in a Jyard, if they are still on it they would be the last pieces left of any use at all.
Will check in the upcoming weeks/month.
Old 03-08-2021, 10:50 PM
NOT A TA NOT A TA is offline
Went out and looked at the ones in my car. If it's the curved piece I think is what's being discussed they'd be a pain to make without having one out of a car to use as a pattern. Even with ones as patterns trying to make them without a press would be time consuming.
John Paige
Lab-14.com
Old 03-08-2021, 11:10 PM
X2 on ALL he said ^^^^. I did cut out a pair for Gregggg for one of his cars. I cut way around them.
Since I need to replace one coming up this summer, I may try to get one out in one piece for a pattern, make it a printable template or something.
Old 03-09-2021, 12:43 AM
Yes the curved piece that fills in between the quarter and the metal tail panel ,bought several pairs of these back in the early 80s when replacing 1/4s on early tas .never heard of now and very difficult to get off
Old 03-09-2021, 12:44 AM
Did anyone ever reproduce lower inner tail panel that goes from the trunk floor to the bottom of outer tail panel for 70 to 73?
