Old 03-07-2021, 10:00 AM
goat guy goat guy is offline
Default Gas tank sending unit
Ok, got rid of the repro sending unit. Registers the correct amount of gas in tank. The question is, when I turn of ing switch the gauge goes to infinity. When I turn the key back on, it goes to what sin the tank. If I disconnect the battery, the same thing happens. Is this ok? Is there something to do so this doesn't happen. Thoughts??
Old 03-07-2021, 04:28 PM
Bill Hanlon's Avatar
S.O.P.
Old 03-07-2021, 08:08 PM
OG68 OG68 is offline
it's been my experience with older GM cars that the needle either stays in place or goes above full when the igntion is turned off
Old 03-08-2021, 09:53 AM
Default Sending unit
It is the original unit in there now. Cleaned it
, tested it, new sock al was good before install. Just want to make sure all is OK.
