Old 03-09-2021, 05:15 PM
trshman's Avatar
trshman trshman is offline
Default Need Rubber/Silocone Valve Cover Gasket
Can anyone recommend a good rubber/silicone valve cover gasket for a '70- 400 engine. I checked with Fel-Pro and they don't make one.
Any help is appreciated.
You all have a good day. trshman
Old 03-09-2021, 05:43 PM
Navy Horn 16 Navy Horn 16 is offline
https://butlerperformance.com/i-2445...tegory:1234816
These are great.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
Old 03-09-2021, 07:04 PM
Half-Inch Stud's Avatar
Craaap, i just bought 3/8" thick cork from butler for about the same money.
Old 03-09-2021, 08:38 PM
Bermuda Blue Bermuda Blue is offline
https://www.bopengineering.com/beltd..._topend3.shtml
"Pontiac Steel Core Valve Cover Gasket
The BOP Pontiac steel core Neoprene (rubber) valve cover gaskets are the ultimate in sealing and reusability. The steel core maintains the shape of the gasket for improved sealing especially in vacuum pump applications. Gaskets will not get sucked into the valve train area and or tear like cork. At 3/16 inches thickness (.187") they also aid in clearance issues with roller valve trains.
Pontiac Steel Core Valve Cover Gasket (pair) (VCG45R)... $19.99"
BOP Engineering also has a one piece oil pan gasket
The Following User Says Thank You to Bermuda Blue For This Useful Post:
Old 03-11-2021, 06:03 PM
NeighborsComplaint's Avatar
I run these. I like the steel core because they hold their shape and stay in place without sealant. They have a rib around the inside and outside edge that nests tight around the cylinder head flange and provides a good seal against the valve cover.
Triple Black 1971 GTO
Old 03-11-2021, 07:21 PM
Old Goat Racer's Avatar
Or these http://krepower.com/Pontiac%20Gaskets.htm
Everybody knows somthin.
Nobody knows everything !
Old 03-11-2021, 07:35 PM
tom s tom s is offline
I have found you need at least 5/16 thick to help with roller rocker clearance.Tom
Old 03-12-2021, 09:29 AM
trshman's Avatar
Thank you one and all. I bought some off ebay from an RH Jones company who claims to be the manufacturer. They're silicone with a steel core, $22 bucks incl shipping. Bought them on Tuesday, arrived Thursday. They look great, I'll let you know how they perform.
The Following User Says Thank You to trshman For This Useful Post:
Old 03-12-2021, 10:40 AM
Murf Murf is offline
Hey trshman could you post a link to those? I can’t seem to find them.
Murf
Old 03-12-2021, 11:10 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
https://www.ebay.com/itm/Pontiac-Ste...QAAOSwsbhgJanM
Old 03-12-2021, 11:20 AM
Thanks 400 Lemans! Don’t know why I would see them the first time I looked.
Murf
Sent from my iPhone using Tapatalk Pro
Old 03-13-2021, 02:27 AM
Yup. Those are the ones I am running. I forgot to paste the link. 3/16 thick but they work great.
