THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
What did you do to your Pontiac Lately?
I have been searching for a set of Street Edition wheels for my 2009 Solstice coupe for about a year now. Got lucky and found a set. Those and the blacked out headlights complete the outside of my 1 of none Street Edition coupe
1st picture is the original non polished 2009 wheels, the 2nd is the Street Edition Wheels mounted. 3rd Picture is the original chrome headlights, 4th is with the Blackened headlights used on the Street Edition and Turbo Coupes only. Lets see what every one has been up to lately!
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) Last edited by camerjeff; 03-26-2021 at 07:32 PM. Reason: forgot pictures |
The Following User Says Thank You to camerjeff For This Useful Post: | ||
Beautiful car Jeff. They should have made more of the hardtops.
Now that's one to hang on to for a long time. Instant collector's car. Looks sweet, but how in hell do you see out of it.
I've only seen one, in grey, that's in this area, and plated for Delaware. Right in the area of it's birth place. The GM plant is gone and in it's place.... a freekin Amazon warehouse that takes up more room than the GM plant did. It even covers where the Anchor Mtr Frt terminal and garage was, and the loading area to get them out to the dealers.
Put second gen door mirrors on my 68, installed driver's door hinge pin bushings & detent plate, installed drive shaft safety loop, rebuilt Quadrajet per Cliff's kit & recipe (testing & adjustments, if needed, in better weather).
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
You must have some really long days up North lol.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express 2024 Cadillac LYRIQ |
New engine in the 37. Getting close, just need to wire up the new fan controller and put the front end back on. Hopefully this weekend!
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 77 Grand Prix base model, 350 pontiac 97 F250 7.3 turbo diesel 85 CJ7 Laredo 65 Impala SS 396, 4 spd, A/C. |
The Following User Says Thank You to moneypit For This Useful Post: | ||
Man, aint that the truth..........................
Which Pontiac?
My '59 GMC/Pontiac came out of storage, got a set of air shocks with onboard pump/controller, and a new pinion seal on the Posi rear end. Crossed a few things off the list for the Pontiac powered lakester. Replaced the alternator belt on the Wangers' Bandit Suburban.
Did manage to get mine fired up for the 1st time this year. Not out of the garage yet though, close. Did get my one of my LED tail lights fixed.
Have some other stuff to install yet, Global west Bump steer arms, and a New proforged center link. Then will do another alignment, Have a new machine at work to try out on the Lemans. Also have a new turn signal switch that needs to get installed, have had it for a few years, LOL. Old one does not cancel all the time and then the left brake light does not work when I forget to make sure it got centered. Hopefully get her out on the road soon. Weather is starting to warm up and have seen a few rides out already.
64 Lemans hardtop 4spd, buckets |
Finally got my brakes put back together after quite an ordeal. Then discovered I had zero compression in cylinders 2 and 4. Off for rebuilding go the heads.
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
Rowed the gears in my 73 Formula 400 4spd. Smoked the tires the 69 GTO. Sold the 63 LeMans and nearly sold nearly sold my 544127 SD heads. Good times!
DragStarLeMans |
The Following User Says Thank You to Drag Star Le Mans For This Useful Post: | ||
New plugs and air filter and drove to the track for the first time this year. Got my best 60', et, & mph but not all on the same run. Great day!
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Glad to see some of us are getting back on the road, money pit that looks like it is going to be quite the ride when its done!
Jack, you are like me to many projects going at once! I also swapped out the worn cloth seats for a set of decent black leather seats a couple of weeks ago on the coupe
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Mine are in storage waiting for some work to get done and then transported to my new house. Very very slow progress due to medical issues.
Have my motor ready to pull. Dropped out the th400 and currently fitting the new TKX. Once I know it clears tunnel will pull engine for a clean up and replace leaking oil pan. Looks like tunnel will need a little hammer work only and tranny should fit nicely
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet Th400 gone. Tkx close ratio with .64 of 66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it |
Adding power locks to my 76 Firebird. Just finished my RetroSound stereo and speaker installation. Sounds awesome.
Cleaned and adjusted the driver's side window regulator that I had mistakenly lubed with white lith grease years ago and it was locked up. Works fine now. Took it out on errands today and banged some gears. I've had this one for 39 years and never get tired of it.
Jeff |
Keeping it in working order and driving it every chance I get...
Today was some of the first steps back to NORMAL and friggen long overdue!!
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Pulled alternator to have new bearings put in, replaced fuel pump, fixed choke. Have a new set of rear leaf springs and sub-frame connectors ready to go in.
Still having the metal finishing done to bring the body into shape...Ordered 4-gallons sprayable of epoxy primer. Hoping to get the epoxy on the metal as soon as temperatures allow.
The Following User Says Thank You to 1_Wild_Cat For This Useful Post: | ||
