Old 03-31-2021, 02:00 PM
Default Formula (Ram Air) Air Cleaner
I need to replace the vacuum actuators in the snorkels of my 1971 Formula HO/RA air cleaner. I tried using the ones that Ames sells, but they're for GTO's and they will not work. (FYI, Ames told me they were not sure they would work for my application, so they're not to blame here).
It appears that both of my actuators are the same, so I'm thinking there may be just one part number for the actuators. I'm hoping someone can provide a part number for me so I can try and find NOS or aftermarket replacement actuators.
I did find some that might work (see link below), but they do not sell the actuators separately, you have to buy the entire kit and I'd rather not do that yet.
https://www.firebirdcentral.com/1970.../enc-2059a.htm
The black actuators in the pictures are the ones I got from Ames. The rod coming out of the actuators are too long, and they point in different directions, while the original actuator rods are shorter and point in the same direction.
Name:	RA air cleaner.jpg
ID:	563768   Click image for larger version
ID:	563769   Click image for larger version
ID:	563770   Click image for larger version
ID:	563771   Click image for larger version
Old 03-31-2021, 06:49 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
If you can't find NOS, and end up using the replacements, I was able to carefully straighten the rod and then bend it in the correct direction. If needed you can change the height of the rod when you re-bend them and then trim the end after bending it as needed
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 03-31-2021, 08:16 PM
I considered doing that, but the rods are not very thick, and I'm concerned that the rods will break off when I try to bend them. The rods are too long, so the first thing I would need to do is straighten them, then cut them to length, then try to re-bend them in the correct direction without breaking them. I might have to try that, but figured I would try to see if I could just buy the correct ones first. I also considered cutting the rods in the center, and cutting out a section so they're the right length, then tac welding them back together facing in the correct direction. I don't know if that would damage the vacuum pod though.
ID:	563818   Click image for larger version
ID:	563820   Click image for larger version
ID:	563821   Click image for larger version
Old 03-31-2021, 08:41 PM
Norwood's Avatar
Norwood Norwood is offline
I’ve twisted the rods with no issues. Don’t scare!
The Following User Says Thank You to Norwood For This Useful Post:
Old 03-31-2021, 08:43 PM
70 Blackbird 70 Blackbird is offline
Here is what I found on my Firebird part CD:
3.415 DIAPHRAGM PACKAGE, CARBURETOR AIR
CLEANER /ON SNORKEL/
6484248 1970—71/ALL W/DUAL SNORKEL CLEANER —RIGHT
6484246 1970—71/ALL W/DUAL SNORKEL CLEANER —LEFT
6484247 1971/4BC - SINGLE SNORKEL CLEANER
Got a couple hits via a google search.. so you may be in luck...
Let us know how it goes...
Old 03-31-2021, 08:56 PM
Thanks. Did they show a different part number for these actuators for Ram Air cars? I'm wondering if they're different because the non RA ones are on top of the snorkel while the RA ones are on there underside. Maybe that's why the rods are shorter on mine than the GTO ones I tried using. Also, both of my actuators look the same, so I was thinking they might use the same part number for both of them.
Old 03-31-2021, 09:29 PM
RA is not specifically called out in the parts listing.. I checked my catalog through to 76 and it gives the same part numbers, listed as through 72.. No left/right listed for 73-76..
Name:	Gp 3.415.jpg
Old 03-31-2021, 11:26 PM
Aus78Formula Aus78Formula is offline
The rods are held onto the bellows with a rivet, spray something in there and will help them turn if needed.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 11-12-2021, 05:51 PM
Ramairnacho Ramairnacho is offline
Default Ram air air cleaner
I misplaced my original 1970 ram.air air cleaner need help locating 1. I'm Ignacio 9254358055
