Old 04-01-2021, 07:55 AM
mysticmissle's Avatar
Default Good reference pics for starter wire routing on v8 car
I did not do enough research and am
In the garage on my phone lol. Does anyone have a series of photos that shows the battery cable going from batt to starter on a 69 v8 car w factory hi performance dport manifolds? Stick car. I know I need to come off the back of the head
What is the routing to that drop off point? I
Am
Converting an ohc car so all of that was closer to the battery. Thank you
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-01-2021, 09:03 AM
rdl's Avatar
rdl rdl is offline
Post
Does this blueprint help?
'69 R/A III Firebird Convertible
14.0s @ 100.8mph AMA/OEM/OER
Old 04-01-2021, 09:52 AM
Not sure the battery cable comes from back of head?
The alternator wire and start wire do I think.
My pic is sharper than what PY shows.
Old 04-01-2021, 10:19 AM
That makes a lot more sense. I had stumbled into something showing an ho car had a tube at back of the head Buy it’s possible I was looking at either solenoid wires or a body cars thank you both
1964 540 gto
Old 04-01-2021, 02:22 PM
rdl's Avatar
rdl rdl is offline
There is a tube in the back. You can see it in view B of the second posted schematic blueprint. It carries wiring to the solenoid (just not the battery cable).
Old 04-28-2021, 11:42 AM
Hotrodjohn71 Hotrodjohn71 is offline
I'm looking for one of those L shaped starter wire tubes for a 1967 v8 car if anyone has an extra.
