Old 04-09-2021, 03:57 PM
thepontiacman's Avatar
Default Special 2 piece 400 Crankshaft Found Today
Check out what I found in this 400. Not a good thing to find. Late 70's 400.
2 pieces now.
Sent from my Moto Z3 Play using Tapatalk
Old 04-09-2021, 06:22 PM
einstein's Avatar
einstein einstein is offline
If they fracture just right, they still run. The knock is rather odd.
The Following User Says Thank You to einstein For This Useful Post:
Old 04-09-2021, 06:35 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
I'll bet my water pump is going south...
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 04-09-2021, 06:44 PM
PontiacJim1959 PontiacJim1959 is offline
An 800HP shot of nitrous from a stand still will do that.
Old 04-09-2021, 09:48 PM
694.1 694.1 is offline
well, photo 1 clearly shows a hole!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 04-09-2021, 10:15 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I had one of these cranks in a 76 455 TA engine... It still ran just knocked a lot!
https://www.facebook.com/PaulKnippen...9523455937204/
Very rare option
Go fast, see Elvis!
Old 04-10-2021, 08:10 AM
Half-Inch Stud's Avatar
. Drill hole.
Made me look at CYL 1; looks like a dented lower CYL.
Old 04-10-2021, 08:14 AM
4dblnkldude's Avatar
Very rare option
I've chased that knock before. I sold my neighbor a 455 for his 70 lemans, just a crank and block. He had the engine built locally by a well known guy. Thing was a runner dynoed at 520hp. Stock e heads, roller cam, etc. After 100 miles it started knocking. We had that effing trans out twice, flexplate magnafluxed, a new converter, the driveshaft balanced you name it. The car sat for two years and he finally got back on it. We pulled the engine and took it back. Yep the crank was cracked, had good oil pressure though.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 04-10-2021, 08:37 AM
Exactly
I once bought a real nice '66 GP with an engine knock. Drove it about 20 miles home with the A/C blowing ice cubes. Took it apart, and the crank was in 2 pieces.
Old 04-10-2021, 08:40 AM
mrennie's Avatar
mrennie mrennie is offline
Originally Posted by thepontiacman View Post
Great picture to show the "overlap" of rod and main journals. There isn't as much as you would think when viewed from this angle.
Very glad my factory 455 crank has larger mains to maintain as much overlap as possible!
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 04-10-2021, 08:43 AM
flamedabone flamedabone is offline
This happened the last 25 miles of a 3000 mile trip. The oil pressure hovered around 20 and she knocked like hell, but she made it all the way home.
-Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5
1933, 1934, 1936 and 1940 Fords, also Pontiac powered.
Old 04-10-2021, 08:47 AM
#1 main brg. Spun .When I pulled timing set off , the one side of the main brg slid out. Took rod nuts loose and there was lots of movement of the broke part of crank.
Main cap is chipped around dial pin.
Cylinders look good, so far.
Align hone/bore and replace crank/main cap and it may be good to use.
Going to put another short block in it's place to sell.
Old 04-10-2021, 11:17 AM
gtohunter's Avatar
gtohunter gtohunter is offline
2.8 GM V6...Drove it home. Clutch was a little squirrely though!
Jimmy M
68 GTO
Old 04-10-2021, 01:03 PM
goats2quick's Avatar
goats2quick goats2quick is offline
had one break just like the one in the first pic.
most people said that a bad ballancer caused it.
67 gto 400/400/3.90(sold)
69 lemans vert 400/400/2.78
89 trans am 350/700r/3.27
67 lemans custom
