Old 04-09-2021, 09:50 PM
Default 1961-1964 AFB fuel line
Could someone post a picture of the fuel line from pump to carb for a 1961-1964 full size car with an AFB and no AC. I only need the section of fuel line that is under the air cleaner. I can't use the bottom section so I am going to bend my own rather than pay $23 plus shipping and then cut the bottom off. I need to clear the air cleaner though. Thanks.
Old 04-10-2021, 08:18 AM
8LUG 8LUG is offline
In 1964 it was a solid line of 3/8" aluminum from the carb to the fuel pump.
Old 04-10-2021, 05:21 PM
gary bennett's Avatar
gary bennett gary bennett is offline
So was the 63 like I have
DBANDGB
Old 04-10-2021, 07:01 PM
misterp266's Avatar
Originally Posted by Goatracer1 View Post
Could someone post a picture of the fuel line from pump to carb for a 1961-1964 full size car with an AFB and no AC. I can't use the bottom section so I am going to bend my own. Thanks.
Gonna guess he knows that but needs to see the upper part.
" Darksiders Rule "
Old 04-10-2021, 11:14 PM
I don't care what the fuel pump end looks like only the end of the fuel line where it goes under the air cleaner. I want it to clear the air cleaner when I bend up a fuel line.
Old 04-11-2021, 08:51 AM
jamesq's Avatar
jamesq jamesq is offline
This is on my 63 Bonneville wagon, I can't take credit or blame, this is how it was when I got it. there is a dimple on the underside of the air cleaner for line clearance.
I hope this helps!
James Q
ID:	564473   Click image for larger version
ID:	564474   Click image for larger version
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 04-11-2021, 10:21 AM
61-63 61-63 is offline
Goatracer google "1961 Pontiac four barrel engine", "1962 Pontiac four barrel engine" etc. and look at the pictures. I just did and what you want to see are on the internet. The line turns forward immediately after exiting the carburetor and angles down and runs along the inside the edge of the valve cover and then bends down at the front edge of the block where the fuel filter is located above the fuel pump. The pictures I refer to are with the big factory air cleaner in place. I would have saved and posted two or three of the pictures I saw but for some reason they came up blurry on my screen.
James Q what you are showing is not factory.
Old 04-11-2021, 12:06 PM
jamesq's Avatar
Thanks for the clarification, I was trying to help!
James Q
James Quayhagen
Old 04-11-2021, 01:48 PM
James Q
No criticism intended.
Old 04-11-2021, 04:20 PM
Thanks 61-63. I'll do that. Thanks jamesq for trying.
Old 04-12-2021, 12:16 AM
jamesq's Avatar
None taken, thanks
James Quayhagen
