| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
How much would you spend on a Ram Air IV SR engine complete carb to pan??
I'd say around 7K if it is NOS and just needed gas to fire it up.
Really? That low? Aren’t heads going for $4000?
Probably would need more information to give an honest number to this fishing expedition. A Ram Air IV SR engine complete? How complete? Does it have the exhaust manifolds? Were original intake manifold, distributor, accessories bolted to a SR block? Or is the entire assembly SR? Does it have the original Ram Air IV Q-jet?, or a SR Q-Jet? or just a Q-Jet? All these things have an effect on the value to a high degree. Also you didn't mention if this engine is a USED SR engine or an NOS SR engine. Of course that would have a huge effect on value. From a practical standpoint, having owned, worked with and raced Ram Air III, IV, HO and SD engines, it's mostly about how they are tuned and cared for that determines their performance. Certainly the 4 HP rated bump between a Ram Air III and Ram Air IV is a fantasy, IMO, A stock Ram Air IV does not have 75 to 100 + more HP as sometimes spouted in the magazines. It's an honest 25-30 HP bump, not the holy grail most lucky enough to own one like to think. The bump in the car's value is much greater than the decrease in quarter mile times.
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
The ebay potential might be higher than the "what would you PY'ers pay for a RAIV" as described
I would guess a complete unused top to bottom IV would go for 10K easily in todays crazy $ market. Might go for more if a couple bidders really want it. 15K wouldn't astound me.
72 Bird |
The block is SR, every other part is original RA IV equipment from 69’
Has literally every part, carb, intake, heads, ex manifolds, dist, pistons, cam, crankshaft, oil pan, even a lower pan and air filter. Was a running motor, car got killed, wrapped around a pole... this was many moons ago, but the engine hasn’t been opened since pulled. I have an original ’69 Judge RA IV car. Would like to make it complete! |
I have seen 400 4-bolt SR blocks dated into the early and mid-1970s. I think I still have a 4-bolt SR block with a 1973 cast date. The same goes for the heads and carbs. Original 1970 dated parts are worth far more than SR parts. The original Ram IV heads had no casting date visible. The date was under the valve covers and was partially machined away. Later over the counter Ram IV heads have a casting date in the normal location. And an Ram IV carb with a 1970 production model date is worth far more than a SR carb with a later date. It is definitely a valuable engine, but to bring maximum dollars the dates would all need to match up with a production car.
Mike |
Are you looking to buy it? Your description makes it sound like you can add gas and fire it right up, but I think that's a BIG assumption. There are probably a few engines at the bottom of the ocean that were "Running when pulled."
Well it sounds like YOU are the guy this seller is looking for! How much should you pay? I will leave that to the experts. But plan on a complete disassembly and refurbishing of the engine if you intend to do more than drive it into and off a trailer. To run properly and provide fun and reliability, any engine that has been sitting around for 50+ years will need rings, valve springs, gaskets and seals at a bare minimum to really run properly. Good luck with your potential purchase.
While not quite as valuable as an original 1969 RAIV block, the SR blocks have considerable value. ESPECIALLY if they have 1968-9 date codes and more especially if they have the complete, AS-CAST, 9792506 casting number.
Using known sale prices over the past few years, I’d calculate it is worth a LOT more than $7k. Probably more like DOUBLE that to the right guy. PYers are notoriously frugal….. SR block $4500 Heads $4000 Rockers, pushrods, RAIV specific deflector parts $350 Intake w/crossover $2000 Exhausts $500 Distributor $2500 Carb $3000 Air pan $1500 Crank and rods $300 Camshaft $150 Oil pan and timing cover $200 Balancer and pulleys $200 Valve covers and PCV tube to air cleaner $200 Being able to get it all-at-once in one package would be a plus. Good luck! |
I’m admittedly fugal as well. That made me laugh tho!
PY'rs purchase for $5.00 bucks and sell for $1 million
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright" |
| The Following 5 Users Say Thank You to 02Hawk For This Useful Post: | ||
Not just PYers are frugal, I worked at a Pontiac dealer back in 1970, the year I graduated from HS. I also specialized in Pontiacs when I owned my own garage and service station. Pontiac owners as a whole are frugal, always have been since I have been around them. My father and grandfather also worked at the local Pontiac dealer back in the late 30s, they both said the same thing, but frugal wasn't the exact adjective they used.....LOL
| The Following 3 Users Say Thank You to Sirrotica For This Useful Post: | ||
My father who owned five different Pontiacs while I was a child was definitely cheap. All of them were bare bones except the OHC Firebird with the Q-jet and four speed.
$7,100 for me. Pass it on.
Wouldn't be interested. Into the earlier (pre '68) cars. Always have been. Never been real keen on all matching numbers, either. Just like driving them.
Jeff |
10-15000 if compete and correct
Anyone thinking they’re going to pick up a complete RAIV engine for less than around 20K is dreaming.
Highly desirable and rare equals high priced, these engines belong in cars that are also rare and pricey. Anything equipped with a top performance engine option from the muscle car era brings top dollar.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 2 Users Say Thank You to b-man For This Useful Post: | ||
| The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
It' will be hard to find a date correct RA IV non SR in nice shape. I've been looking for years for the matching #'s 70 RA IV GTO that my XP motor came out of. This one is rarer then my WW 70 GTO, it's a XP (around 140 produced) all complete with rebuild with all OE parts minus the carb, I even have the #'s matching tranny. I was offered $12,500 years ago and wouldn't take it. Maybe I'll find the car or a 70 deserving of this combo. For those not familiar with a RA IV, they have a unique sound and rumble that makes one smile and will pull some RPM's. I believe B Man is right on spot with his estimate. As to who buys one mgarblik is on spot too.
