Old 04-25-2021, 07:11 AM
gtospieg gtospieg is offline
Default 65 Corvette....electrical
Helping a friend with his Corvette...The car is not fully assembled. We installed his rebuilt windshield wiper motor and with a test light it shows power at the ground strap on the wiper motor. Obviously this can't be correct. Where do we start looking for the problem.
Old 04-25-2021, 08:32 AM
Well I would start checking all of your grounds. Clip a jumper wire to ground and the strap your wiper motor will work. You say not fully assembled that most likely your problem.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 04-25-2021, 08:38 AM
NAPA68 NAPA68 is offline
The motor is controlled through the ground. In other words, it grounds through the switch.
Is there a problem you are trying to correct or just checking before lighting it up?
Perhaps this will help.......
http://repairs.willcoxcorvette.com/w...tor-wiring.pdf
Tim
The Following User Says Thank You to NAPA68 For This Useful Post:
Old 04-25-2021, 06:53 PM
NAPA68....thanks for that info...I will pass it along.
