Old 05-03-2021, 10:16 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
Default Can this be sleeved effectively?
....and the followup......would it be worth it to do so?
Many moons ago, a friends '73 .020 over 455 ate a threaded rod from his valve cover T-handle. He finally decided to let the block go. He was going to scrap it, but it pains me to a see another traditional Pontiac block leave this planet, so I'm curious if it can be saved.
Can this be fixed? Pretty hefty crack in #2 cylinder wall. Thats the only damage. All else looks good, just needs a cleanup.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 05-03-2021, 10:52 AM
track73 track73 is offline
I see no reason why it can not be sleeved successfully. I would however since its only .020 over have the block bored to ,030 because sleeving can distort the adjacent cylinders.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 05-03-2021, 11:36 AM
steve25 steve25 is online now
That crack looks like it may go all the way up into the deck surface so it may need a combination of Boring, crack stitching and sleveing.
A Mag test needs to take place first in other words and if that clears the way then drilling or grinding out the ends of the crack and boring and sleveing will get it back on the road.
Old 05-03-2021, 04:31 PM
Schurkey Schurkey is offline
^^^ Damn fine answer.
Old 05-03-2021, 11:24 PM
73LeMans's Avatar
I think they were all damn fine answers! Heck, I didn't even know crack stitching was a thing..... and .030 it goes. Thanks!
Mark S
>>My 73 Build thread
