Swap cam while motor is In ?
Is it possible to change the Camshaft out while engine is in the car ?
1980 TA Thanx for any help here .
http://www.youtube.com/watch?v=DtKk5GNtWH0 Life is tough. Life is tougher when you're stupid. -John Wayne |
Yes, the hood latch support bar will need to be loosened and pushed out of the way. If the car has AC the condenser will need to be moved around but shouldn't have to be disconnected.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Thanx, this eases my mind .
The Following User Says Thank You to Billz428 For This Useful Post: | ||
Absolutely
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
If your doing it on your own then do yourself a big favor.
Get some Mechanics wire and slip it in some vacuum hose or fish tank tubing, form it into a loop up so you can slip it over the end of the cam to support it as you progressively slip it all the way in. Also once you remove the old Cam take a good look with a mechanics mirror at all the old bearings to look for signs of them coming as they tend to do at times,
Did this in a 2nd gen this past spring. I remember having to move the center crossmember/hood last deal.
I think a screw in cam install tool helped too. Biggest pita was getting it timed/degree'd and messing w/ a snug .005 timing set. Dropped a sims - shim into from of pain. Magnet and patience found it (Make sure you stuff rags in front lip of oil pan - I had done that, but somehow it got past). Put in the older Ole Faithful per Dave's recc for my motor. My timing set allowed 2 degree's per adjust. I could either leave it retarded 1/2 degree or advanced 1 1/2. I went advanced...I figured once the timing set was broken in I'd lose 1/2 degree + anyway. 455/76 TA. Its a beast. Take your time. Somewhat of a pain to do in car. Use the right cam..lol. |
Non-AC is easy.
With charged AC is impossible. |
A crank socket with a degree wheel on it is easy to use also.
I can’t see how it can be done with A/C without disconnecting the condenser!
The Following User Says Thank You to steve25 For This Useful Post: | ||
I have even changed out 4 out of 5 cam bearings in my 70 bird in the engine bay about 15 years ago now
Steve there is enough room to just unbolt the condensor and enough slack in lines. Just need a little room there is all. Biggest deal is the latch brace. But all the swaps I was doing I pulled mine.
Car has A/C removed long ago.
Next week.i start this adventure . Thanx Everyone .
Note that as soon as you get the timing cover off if the 2 lower bolt hole sleeves are not in the cover, but still on the face of the block do as posted above, pack the open nose of the oil pan until it’s overflowing with paper towels and then remove those two guide sleeves.
Form-a - gasket them in lightly into the timing cover so they do not fall out during reassembly and fall in the pan when the paper towels are no longer there!
The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
And keep the pan packed until the timing chain goes on-be sure the cam key is a tight fit! Ask me how I know-luckily a skinny magnet retrieved it!
Way loose Chain.was found .
Had been line honed . 4 bolt caps installed. a standard timing set had been installed . Maybe 8 tanks of gas, cruzing Going forward to.the New Lunati grind . Lots of slop.
Found this .
Tried to.post a video
Done that a few times.
Sloppy chain
Found this .
