Old 05-08-2021, 07:20 PM
67drake's Avatar
67drake 67drake is offline
Default Need help finding correct Silverado wiring harness
Oh brother. I’ve spent hours now looking for this.
My rear passenger side tail/brake light went out. I got a bulb and pulled the light. I found water in the housing and the connections so corroded that the one not working socket fell apart.
OK, I call around and look on the internet for a new harness. EVERY one I find has the 3047 bulb for the back up light. I have an apparently rare 921 back up bulb, they’re not interchangeable.
I’ve tried all my usual web sites and no luck. Any ideas?
Thanks!
BTW- it’s a 2011 Silverado
13.95 @ 102.1 on street tires @ 4055lbs.
Old 05-08-2021, 07:54 PM
67drake's Avatar
Well, if nobody can find one, I figured out a plan B. I found an aftermarket housing/lens that comes complete with a new harness for $43. I can live with that. Quality is probably crap though. So I would have a 3047 bulb on one side, 921 on the other. Just cross my fingers that the harness plug is wired the same.
Old 05-08-2021, 08:54 PM
LPete LPete is offline
The 921 has one filament, and the 3047 has two. Something other than just the bulb is different.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
Old 05-08-2021, 10:30 PM
67drake's Avatar
Yeah, I thought of that. I don’t know if just one filament is used, or both. If I order the light/harness, I’m going to crawl under the truck to check and see how the current harness is wired, as compared to the new one.
It’s all kind of bs. There is millions of these trucks on the road. I can’t see me being the only one in this position. I could always go to the junk yard an get another plug, but how much better shape is one going to be here in Wisconsin? My truck spent its first 8 years in Arizona.
Old 05-08-2021, 10:36 PM
It looks like Rock Auto has both versions.
Lee Peterson
Old 05-08-2021, 10:38 PM
67drake's Avatar
Really? I looked this afternoon and only saw the one style, left and right side.
I’ll check again.
Old 05-08-2021, 10:44 PM
67drake's Avatar
I’m showing only 3047 bulbs harness
Old 05-08-2021, 10:53 PM
Ah, I was looking at the whole lamp assy. They show both of those.
Lee Peterson
Old 05-08-2021, 10:57 PM
Maybe...I was guessing at 1/2 ton, since you didn’t say. Lots of choices.
Lee Peterson
Old 05-09-2021, 10:07 PM
fyrffytr1's Avatar
push come to shove you could replace both harnesses and use the 3047 bulb or the 3157 LED bulb.
Old 05-10-2021, 09:36 AM
FrankieT/A's Avatar
Why not just replace the pig tail?
Old 05-10-2021, 07:23 PM
67drake's Avatar
I hate splicing into a wire harness, they always seem to corrode up in the rust belt. Also can’t find a pig tail that fits that light housing. But, no other choice at this point. I’m just going to the junk yard Wednesday and get a couple off of a parts truck. What a crock.
Old 05-11-2021, 12:16 PM
jerry455 jerry455 is online now
If you get a good kit they will have the heat shrink butt splice connectors with the glue inside that melts and encases the wire. That is the best and easiest way to do it.
Old 05-11-2021, 07:17 PM
67drake's Avatar
Well, a fellow member got ahold of me an gave me the part number for a new harness. I don’t know why they’re so hard to track down. I just ordered a new one.
Thanks people for the help
