Old 05-11-2021, 01:57 PM
brodad brodad is offline
Default Oil pan center link issue?
Ok 64 Lemans originally a 326 swapped in a 67 400 oil pan was bad got new Canton 15-389 pan ant the center link hits the pan and the tie rods do.as well any got a different pan Transdapt TRD9337 same issues. Both aftermarket pans measured approximately 4.5" from top of them to bottom of the pan where the issue occurs,the 326 pan is approximately 3.75". Will the 326 pan work on the 67?
ID:	566397   Click image for larger version
Old 05-11-2021, 02:09 PM
tom s tom s is offline
Did you put new motor mounts with the installation?Tom
Old 05-11-2021, 02:26 PM
ignaro's Avatar
ignaro ignaro is offline
When I had a Chevy 350 in my 66 Tempest, I had the same issue. Wound up using a pipe to gently dent the pan where it was hitting. Worked great.
Sent from my SM-G988U1 using Tapatalk
Old 05-11-2021, 04:12 PM
Yes I got new ones from Ames also went from ST300 transmission to TH350 with new mount as well. I'm also doing SPC upper, lower tubular control arms, a Right Stuff Detailing front disc brakes swap, new tie rods and a Proforged 106-10060 center link.
Old 05-11-2021, 04:35 PM
I have found aftermarket mounts seem to need a spacer to raise the pan some.Tom
Old 05-13-2021, 09:47 AM
HWYSTR455's Avatar
Trans mount is too thick/high.
