As far as a plug and play dist....which one would you recommend? MSD,,pertronox,,etc. I prefer to use one of the small bodies.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
DUI
1970 GTO (Granada Gold) - 400 / TH400 |
happy with my MSD ready to run. I have one in my GTO and one in a big block chevy. Both were built after the corrosion issues were evidently resolved. Both have digital 6 AL2 boxes and have been flawless. Easy to tune, too, with the bushings and weights.
The only thing I’d like to see them add is a nice adjustable vacuum advance with both the internal hex-adjustable rate mechanism and a total vacuum advance limiter. I think Crane used to make such a part but I haven’t messed with tuning lately so I am not sure. |
What ever you get make sure it has a vacuum advance if it's a street driven car
Tim Corcoran |
X2 on DUI but it's a full size cap. I also ran a Summit for 10yrs and many miles. Both worked great
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
MSD ready to run. Swap the cap to a black one and you are ready to roll.
I have one in the 67 street car and it works really well.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
| The Following User Says Thank You to Mike Davis For This Useful Post: | ||
I honestly think they are mostly the same. I have an accel one that is no longer made. No matter what you will find 8 people who say they are great and two people who claim it stranded them on the side of the road.
I had an HEI and switched to the small cap which I like much better. The only great thing about the HEI is you can have all the replacement parts in the trunk cheaply.
I currently run a dui small body I bought new probably 4 years ago. Ever since I put it in it won't hold timing. I set my timing with a timing gun that has a dial for total. You can tighten the clamp all you want but for some reason it can creep advance or retard after you run it hard a few times. Just did it again,,,they set total at 32 on the dyno...once in the car I confirmed 32 total with my gun. Git a few miles on it now and it crept back to 30. I let it cool off over night and checked it again this morning...30 total. Now I noticed one of the wires that goes from the external module into the bottom of the dist has some burn spots on the insulation. The only way I can see that happening is if the wire leaned on the module which might of been hot. Or it got hot from the inside. Look at the yellow wire,,there's like 3 burn spots.I'm just kinda tired of it.
I had no idea they had a small cap HEI. Mine has never lost or gained timing. I used the mechanical advance only with my old 400 and use it locked out now. Only issue I had was the carbon button under the coil wore down.
If electronic is what you're after, I've always run, and always had excellent results, with MSD.
In fact the original vacuum can that came in the MSD in my chevelle gave up just this year after 25 years of use. I pulled it out to find that MSD had used the popular B28 can in it. I simply swapped in an adjustable unit from Crane, modified it the way I've mentioned on the forum here in the past. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
'65 Tempest 467 3650# [email protected] |
I maybe getting a msd ready to run small body. At the track now,,,only made 2 runs and traction is a problem with the street tires. Anyway I left the house and was right on 32 total. Drove little over an hour to the track and made 1 run. Checked total after and it went to 29. Adjusted it to 33 and tightened as much as I could. Made another run and now is 34 total. This is what's been going on with it sinceI bought it...I've had other makes of dist and never had this problem before.
Scott70,
Does your DUI have an operational vac advance? |
If my distributor wouldn't stay put, I'd be looking at the hold-down bolt for being too long--jamming against the bottom of the bolt hole instead of clamping the hold-down, and I'd make sure there was a fresh distributor gasket between Mister Distributor and the block. Less likely--are the bushing in the distributor housing overly-tight? Have you actually checked to see if you can move the distributor when the hold-down bolt is tightened? That might determine whether the timing shift is mechanical or electronic. There's the wild, outside chance that the damper outer ring is moving around, or the vacuum advance doesn't move smoothly, so it jams in semi-random places/patterns.. Last edited by Schurkey; 05-21-2021 at 08:33 PM. |
Check the fit between the vacuum advance rod and the hole it goes thru. I've seen PLENTY of distributors with enough play there to allow the timing to move around some. It's seldom mentioned anyplace when discussing distributors but the rod MUST fit tight in the hole or you'll never keep the timing at one setting.
As far as making power as well set-up points distributor actually has an advantages over electronic. Decades ago I built a 406 SBC for a good friends race car. It was a low budget engine using a stock crank, rods, good pistons and right out of the box World Products Sportsman heads with only a spring change. It pushed his car to 6.50's at 105mph in the 1/8th mile and well into the 10's in the 1/4 mile. We did the build for under $3000 at that time as the budget was super-tight. We actually used a stock Melling $12 oil pump and an $18 stock wide Morse timing set from a local auto parts store. He'd been running the engine about 10 seasons and saved up enough money to buy an MSD billet distributor to replace the stock points distributor we were using. The points distributor had the advance plate brazed down and timing locked out, otherwise stock everyplace. We installed the "bug zapping" MSD billet unit, set the timing at exactly the same 36 degrees and went to the track. The car SLOWED DOWN about .03-.05 seconds and lost nearly 1mph....WTF? An "old timer" was pitted close to us and we were talking about it between passes. He told us that the points provide a natural timing retard at high RPM's and will run a little quicker than the MSD. Hum, never heard that one before but it makes sense. FWIW my friend went back to his points distributor and runs it with the MSD box, 2 step, etc and still runs it today far as I know..........FWIW.......
Magnetic-pickup distributors also retard based on speed. GM used to say "1 degree per thousand rpm" but it's not that simple. It's gotta be tested. It's approximately 1 degree per thousand, but not exactly.
I didn't know that points did that. In fact, as long as the point spring kept the points under control, I don't know why they would. |
