Old 05-21-2021, 08:18 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Default Rotating Assembly
I see that Molnar does not make 3.25 strokers.
Is Ohio crank the next best choice?
Can you get any dish you need or are there standard dish cc's you "just"have to work with?
It will probably be: 4.18x x 4.25 - 72cc al. heads.
TIA.
Old 05-22-2021, 12:06 PM
steve25 steve25 is online now
Are you building to a hp level that calls for a steel crank?
Old 05-22-2021, 08:01 PM
ponjohn's Avatar
550-600 hp.
Old 05-22-2021, 08:17 PM
Gary H's Avatar
Gary H Gary H is offline
I think I would go with a Scat crank. My experience is that the finished machining is closer to specs than the Ohio cranks
Old 05-23-2021, 09:50 AM
78w72 78w72 is online now
i used a eagle forged crank from butler supplied in their kit with ross 14cc dish pistons. machine shop said it was very nice & didnt need any work prior to install.
Old 05-23-2021, 10:58 AM
Steve C. Steve C. is online now
In 2018 the Crower 4.250" billet crank in my current 505 engine developed a crack. To replace it I bought a SCAT 4340 FORGED STEEL STANDARD WEIGHT CRANKSHAFT thru Paul Knippen. Good service and great price.
No issues or special prep necessary for installation.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
