Old 05-23-2021, 12:54 PM
dlloyd's Avatar
dlloyd dlloyd is offline
Default Blinker cancel cam
I replaced my blinker wiring and cancel cam. Now my blinker cancels right at straight ahead in one direction and doesn’t cancel in other direction unless I turn the wheel considerably more than the turn requires.
My question is what is the correct procedure for fixing this ?
Old 05-23-2021, 01:08 PM
Chris65LeMans's Avatar
(This should probably be re-filed under Electrical)
For a '65?
It sounds like pulling the steering wheel off again and taking a close look at all of the mechanics is in order. Something is off - I'm guessing the cam is mis-aligned or something is off with your signal lever.
Old 05-23-2021, 01:27 PM
dlloyd's Avatar
Thanks Chris.
I will repost in electrical
