Old 05-24-2021, 05:49 PM
ejw's Avatar
ejw ejw is offline
Default Pics of 28x10 slicks on early 2nd gen firebirds
Time for new slicks and wanting to try mt pro bracket radial. I currently run 29.5x9 bias on 10” rim and doesn’t stick out past top quarter panel side. Only sell pro bracket in 28x10 and worried would stick out too far. Right now I’m real close too leaf spring so can’t push in farther.
Old 05-24-2021, 11:31 PM
Mike Davis's Avatar
They also make a 28x9 Pro Bracket Radial. That is the size I run. Great tire with long life span.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 05-25-2021, 08:49 AM
ejw's Avatar
ejw ejw is offline
Thanks mike
Was trying to go w bigger width since I would be going w smaller diameter tire. Car goes 6.20s in 1/8
I’ll look into that
Old 05-25-2021, 04:15 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have a M/T 28x10 stiff wall bias slick on my 79 Camaro on an 8" rim. Camaro wheel well a little tighter than a Firebird.
Name:	Cmaro on trailer.jpg
Skip Fix
Old 05-25-2021, 08:42 PM
ejw's Avatar
ejw ejw is offline
Ok
I measured section on my 29.5x9 stretched on a 10” rim and it’ really about same
Thanks for replies guys. Looking forward to trying these tires
Old 05-25-2021, 08:51 PM
Mike Davis's Avatar
Run plenty of air in them. I run anywhere from 19 to 21 depending on the track. Normal burnout first of the day then just clean them off after that. You will like the tire. The PBR is a .10 quicker than a bias and .07 quicker than a Pro 275 on my car in the 1/4.
Old 05-26-2021, 10:35 AM
grandam1979 grandam1979 is offline
275 60 15 drag radials are the same size as 28 10 slicks or real close. I ran drag radials on my 80 t/a for years
Old 05-26-2021, 11:15 AM
Mike Davis's Avatar
The Pro Bracket Radial slicks are different than the 275's.
So far this is the best radial tire I have run.
Old 06-22-2021, 09:11 PM
ZHAWK154's Avatar
ZHAWK154 ZHAWK154 is offline
This is a 28x10.5 pro bracket radial on 15x10 wheel with 5 in backspace
1979 trans am - 462' #12 heads
2001 sunset orange trans am firehawk #154
