Old 05-31-2021, 04:47 AM
92GTA's Avatar
92GTA 92GTA is offline
Default Pontiac parts - 1969 Firebird + others
Most everything is from my 1969 Firebird but may of course fit many other Pontiacs and GM vehicles such as Camaro/Nova, etc. All prices are just estimated market values I found online. If there is no price estimate it's because I have no clue what it's worth.
Many aftermarket items are brand new, so please note if the part has new or used in the description. Let me know what you want, I'll text you a pic, and you can shoot me your best offer.
*If it is still listed below, then it is still available! Local pickup in Bakersfield, CA only. Especially the large heavy stuff.
661-525-0782
[email protected]
$60 - Taylor ThunderVolt 8.2mm spark plug wires, black, build to length (new)
$210 - Holley EFI fuel pump (new)
$160 - Holley EFI fuel pressure regulator (new)
$32 - Holley EFI coolant sensor (new)
$150 - Earl's fuel line (new, 3/8" I think)
$100 - FlowKooler high flow water pump, 11 bolt (used, 10K miles)
$600 - Custom fabricated steed hood louvres/air extractors (new)
$150 - Vintage Air Gen IV AC compressor, guaranteed to work (20K miles)
$110 - AutoMeter gauges (oil & trans temp) & panel (new)
$130 - AC Delco high output alternator, external regulator (sightly used) - will include brand new regulator
$90 - Generic standard output alternator (sightly used)
$125 - Simulated wood factory style steering wheel, 15" (used)
$75 - Deluxe horn button cap (used)
$20 - TH400 oil pan, black (new)
$40 - 1969 Firebird Steering column bearing (new)
$50 - Derale Trans cooler w/fan (new)
$75 - 1969 Firebird power steering box (needs seal; upper seal blew in my driveway)
$50 - 1969 Firebird power steering pump, guaranteed working (used, 15K miles)
$500 - 1969 Pontiac 350 long block (used, 49K miles) - missing timing cover, have distributor, water pump, & damper. Heads are #47 and block is XB.
$100 - Generic traction bars (used)
$150 - Summit mini starter, guaranteed working (20K miles) - didn't need shims on my 400 block
$50 - 1969 Firebird aftermarket factory-style flex fan (used) w/spacer and bolts
$100 - Pypes Race Pro straight-thru mufflers, 2.5" (slightly used, less than 1,000 miles)
$100 - Spare Rally II wheel 14x7 (used, primer, 14")
$??? - 1969 Firebird original radiator (used, 49K miles)
$85 - 1969 Firebird 3/8" factory replacement fuel hardline (new)
$250 - 1969 Firebird V-belt pullies and brackets (for AC) (used)
$65 - 1969 Firebird (w/AC) factory plug wire retainers (new)
$500 - Sparco Chrono seat w/slider & mount, black vinyl w/white stitching (practically new, 2K miles)
$1,200 - Factory original 73K original mile mint Deluxe front seats
$250 - 1969 Firebird rear axle (100% complete, but needs new seals) w/3.23 open diff
$2,000 - 73K POB TH400 w/everything: shifter plate, shifter mechanism, pedal assembly, non-tilt steering column, park position rod/bar assembly, inspection cover (has TransGo performance shift kit installed, 9" 3,400rpm stall converter) - works but could use a rebuild
$75 - PRW 326-400ci neutral balanced SFI flexplate w/bolts
$250 - 1969 Firebird TH400 driveshaft
$125 - 1969 Firebird multi-leaf springs (70K miles)
$750 - 1969 Firebird complete AC system components, even dash vents (49K miles) - but no dash controls
$250 - 1969 Firebird factory front disc brake assemblies (49K miles) - no spindles
$350 - 1969 Firebird original gauge cluster
$150 - 1969 Firebird original date coded front deluxe (black) seatbelt set w/shoulder strap & retainers. Faded and passenger retractor needs new spring
??? - Factory 400 hood scoops (closed, not open)
??? - Fender scallops - both sides
??? - Factory upper and lower a-arms (bushings ok)
1969 Pontiac Firebird
Old 05-31-2021, 02:08 PM
rick c rick c is offline
Send a message via MSN to rick c
Default 69 firebied
Hello Is that gauge cluster you have for sale the stacked gauge , the rally gauges or the the idiot light style? Do you have any nos parts for sale? rick Londonderry N.H
Old 05-31-2021, 03:56 PM
I’m interested in radiator
Old 06-02-2021, 02:53 PM
gobrdgo gobrdgo is offline
I’m interested in steering wheel
Old 06-08-2021, 10:27 PM
92GTA's Avatar
Can't edit the post for some reason.
Rear end, leafs, and traction bars are sold.
Old 07-02-2021, 08:44 AM
zman1969's Avatar
zman1969 zman1969 is offline
sent PM and email about parts - anyone home?
