Old 06-09-2021, 02:30 PM
zman1969's Avatar
zman1969 zman1969 is offline
Default help? 69 F/B center AC vent retaining clips?
my 69 has been apart for years and son and I are slowly assembling it We didnt disassemble it I got it that way anyway my center AC vent has no retainers to keep the cast director? in the plastic housing - what are Y'all using to hold it in its place?
see diagrams its parts #3 that holds #2 listed as outlet retainer
thanks much appreciate the help guys
Old 06-11-2021, 05:18 PM
Pete67FB400 Pete67FB400 is offline
Part #3 isn't a clip. It is just a piece of dense felt used to keep the outlet deflector from rattling and provide enough friction to keep the deflector in the position you set it.
Classic Industries sells a replacement but they are made of rubber and I don't know if they would work the same as the original felt ones. https://www.classicindustries.com/product/9776399.html
You could create your own out of some jute carpet backing pad, some cotton wadding, or a small bit of fabric. Just stuff it in the space to take up the slack and provide a bit of friction.
Name:	HVAC Dash Center Outlet Vent Felt 1.JPG
ID:	568067   Click image for larger version
Name:	HVAC Dash Center Outlet Vent Felt 2.JPG
ID:	568068   Click image for larger version
Name:	HVAC Dash Center Outlet Vent Felt-In Place.jpg
Old 06-14-2021, 02:32 PM
zman1969's Avatar
GM lists a part number and its lists it as a retainer #9776399 ?
and its just felt?
Old 06-14-2021, 08:45 PM
Mine are felt and I have no reason to believe the felt is not original. This post on camaros.net shows a factory box and the pieces inside
https://www.camaros.net/threads/vint...stable.271073/
Old 06-15-2021, 08:59 AM
zman1969's Avatar
thanks Pete seems simple enough the 70 and up are same I guess. Felt will be alot easier to locate at craft shop than some tiny metal clips that I had imagined
Old 06-15-2021, 02:01 PM
I've used in the past a rolled up little strip of paper towel. Cut a narrow strip and roll it up tight, has an almost identical texture as the felt if you just add a tiny drop of oil to keep it "wet"
