What are you guys using for plugs on your High Ports. Most guys seem to run NKGs. Looking for some numbers.
If I can cross reference with the Accel plugs which I like a lot I will. Engine is a 11.5 CR pump gas deal. Thanks for any help. |
I don't have a set of high ports to look at but I'm assuming they use what is pretty much the standard aluminum head plug with 3/4" reach plug, 5/8 with a gasket.
NGK for that number in a resistor plug is BKR6E. Go up or down on heat range as you wish, BKR7E etc.... |
AR3911
11.7 compression 461, this was suggested by Jeff at KRE and the engine shop for my street GTO.
NGK R571A-7 I've run NGK in my Talon and GN and they've always been great.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
I bought the plugs slowbird recommended, found them for 3.30$ on Amazon.
