Old 06-21-2021, 03:00 PM
jhein's Avatar
jhein jhein is online now
Default 70 TA Back from the shop
Ok, well finally got the car back from the shop a couple weeks ago, but I've been busy...
It has a newly rebuilt rear end. It had 4.88 gears and a bent axle. It now has 3.31 gears and a new axle. I also put in a 7/8 anti-sway bar (it previously had a 5/8 which looked original). Had some minor electrical things fixed (horn, reverse lights). Front end alignment, steering wheel straightened, new tires, hood adjustment, drivers door adjustment, throttle linkage adjustment/repair.
Running very good now. Great drivability with the 3.31 gear. No leaks, so they got the pinion shaft seal thing right.
I probably forgot at least a couple things.
Anyway, here she is with the new BFG 245/60 15 front 255/60 15 rear tires.
The Following 6 Users Say Thank You to jhein For This Useful Post:
Old 06-21-2021, 03:07 PM
aljan's Avatar
aljan aljan is offline
Wow, very nice! Looks great!
________________________
1964 GTO 389 TriPower 4spd
1985 Fiero GT 4spd
The Following User Says Thank You to aljan For This Useful Post:
Old 06-21-2021, 04:55 PM
Firedup6975's Avatar
Nice car! Question though was the no trim rings on the rally’s a stock thing with these TA’s? I thought that was only on GTO’s?
~MaryAnn~ AKA "Stickybuns"
1969 Firebird 400 Convertible
1978 Bandit T/A Tribute
1977 RED TA
I'm the FiredUp PY bad girl
The Following User Says Thank You to Firedup6975 For This Useful Post:
Formulabruce's Avatar
Drive ability up 80% ! Bet it makes it a lot more desirable to drive!. I am doing a 3.31 set up now for a buddy
The Following 2 Users Say Thank You to Formulabruce For This Useful Post:
Old 06-21-2021, 04:59 PM
No trim rings were stock on 15" tire birds in 1970 with Rally 2 15" RIMS with the 14" center, which makes a wide lip look on stock $$$$ 1970 wheels.
Old 06-21-2021, 05:15 PM
Half-Inch Stud's Avatar
Looks nice. Hope you keep the Nose sticker in the file cabinet, and the Bumper bare White.
400 will like the 3.31:1.
455 will better like a 3.08:1 ! Posi!!
Old 06-21-2021, 05:21 PM
jhein's Avatar
I read somewhere that the trim rings were available as a dealer installed option. Is that correct or did they not fit at all due to the fact that they were modified 14 inch wheels?
Old 06-21-2021, 09:59 PM
4dblnkldude's Avatar
Nice car! Does it have headers and is it an auto or stick? Reason I ask is I just got a 71 and the reverse lights do not work, I have auto with headers. I remember reading somewhere that with headers some bracket? or something will not make them work. So what was done with the reverse lights...just curious.
Old 06-21-2021, 10:29 PM
padgett's Avatar
padgett padgett is offline
" So what was done with the reverse lights" back in the day I just added a toggle switch on the dash.
Web Site
Old 06-22-2021, 10:45 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Car looks fantastic and I'm sure it is quite a difference with the new gears
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 06-22-2021, 11:18 AM
Trim rings were an option. My '70 had them on the original purchase order.
Old 06-22-2021, 11:22 AM
padgett's Avatar
Just be aware that back in the day there were many Rally II trim rings. Basically originals were sharp edged and shiny. By about '73 they were not.
Web Site
Old 06-22-2021, 12:13 PM
bird72's Avatar
bird72 bird72 is offline
I bet it cruises better. 4.88's are crazy gears. I can't even imagine. With a decent engine, you should have made a racket and laid rubber just trying to drive it, ha. I drove a 455 bird from Oregon to Montana 25 years ago. It had 4.11. There were a couple of eastern Oregon, Idaho stretches where I was just above empty pulling into a gas station. Along with hearing RPM's the whole trip. Had a RAIV cam, so it was my radio. Is your speedo sorted out? That is on my to do list, need tranny gear to correct, I read low a bit.
The Following User Says Thank You to bird72 For This Useful Post:
Old 06-22-2021, 12:16 PM
Gator67's Avatar
Gator67 Gator67 is offline
Congrats on the upgrades. Looks great. Makes me miss mine.
The Following User Says Thank You to Gator67 For This Useful Post:
Old 06-22-2021, 12:19 PM
Oldsmobile rings look the best IMO..
Old 06-22-2021, 01:25 PM
jhein's Avatar
Thanks for all the replies.
Yes, it cruises much more comfortably now. The 4.88 was downright unpleasant. Still has decent acceleration, but I haven't really given her the full juice yet because the motor only has about 250 or so miles on it since the rebuild.
The gear change did require a new speedo gear. I got lucky because when they put in the 4.88 they used a spacer so I didn't have to change the carrier.
The problem I had with the reverse lights was that the reverse lockout lever is missing. Eventually, I'll get that but for now my guy just installed a switch on the shifter that is activated when I go into reverse.
Old 06-22-2021, 10:21 PM
'70 Trans Ams came standard with no trim rings, but the trim rings were an available option for something like $20 retail.
'70 Formulas with the 15" rally wheel option (which was rarely selected, because at ~$150 it was a relatively expensive option) came standard with the trim rings.
Old 06-22-2021, 10:23 PM
I'm not installing anything aftermarket on this car. Its not 1976 and im not butchering this car with other switches or toggles.
Old 06-22-2021, 10:50 PM
Brewster's Avatar
Brewster Brewster is offline
Keith, cool about the 15" wheel option for the 70 Formula. I had not heard that one before.
Car looks straight and it holds a great stance. Love it! Like the jack stand cushions too. Wouldnt it have a 3.08 with a/c and auto and 3.55:1 with a four speed? Why the 3,31 gears set? Just curious on set-up.
Old 06-23-2021, 06:51 AM
SD455DJ SD455DJ is offline
Hey Brew! '70 Auto/AC TA's came with 3.31's in the 12-bolt from what I understand.
Dennis
