Old 06-21-2021, 07:10 PM
jscheublein jscheublein is offline
Default 1964 Pontiac Catalina 2+2 steering tilt column - need help
I am adding a factory tolt wheel to my car - the column shaft has vertical movement - can anyone help on how to eliminate the play.
Jim Scheublein 209-601-4408
Old 06-21-2021, 07:30 PM
stevep's Avatar
stevep stevep is offline
Do you have the correct bracket and the firewall plate? They are for tilt wheel only.
Old 06-21-2021, 09:00 PM
Default 1964 Pontiac 2+2 Convertible tilt wheel
I assumed they were the same (different outside diameter but could use a spacer or modify the bracket to the diameter - I have a machine shop) - if different what is the difference.
Jim
Old 06-22-2021, 08:42 AM
8LUG 8LUG is offline
Default tilt
Picture of the plate and bracket
Name:	tilt wheel bracket.jpg
