Old 06-30-2021, 07:35 PM
gto4evr gto4evr is offline
Default 71 decklid Sport emblem placement
Can anyone give me actual dimensions from the right corner for the two mounting holes for the Sport emblem on the decklid for a 71 (and I'd guess 70 was same placement) I'm doing a new deck lid now, and the lid it's replacing was also a replacement with an eyeballed placement after staring at pictures for days. hoping someone has a real one so I put them in the right spot.
Thanks!
Dennis
Old 06-30-2021, 09:04 PM
fairwayhit fairwayhit is offline
3” and 4 3/8” from the right
3/4” from the bottom
Old 07-01-2021, 09:24 AM
thank you!
Old 07-01-2021, 08:10 PM
just a follow up question, is that an optical illusion with the right hole higher than the left on your pic? you say bottom measurement is 3/4 to both holes? on my car right now it's definitely raised up on the right hole higher than the left but again, I have no way of knowing what was factory on the holes. when I push in the emblem on the left hole and just twist it down so the other pin lays at the same height, the emblem appears to sit slanted, but again, I'm used to seeing it more upright.
first pic: holes as they are on mine, and are within a 1/16" of your left to right measurements
second pic: how my emblem currently sits
third pic: how it would sit if both holes were same height from the bottom
ID:	569085   Click image for larger version
ID:	569086   Click image for larger version
