Old 07-04-2021, 05:31 AM
Aus78Formula Aus78Formula is offline
Default Glovebox lid screws?
I've been looking at various photos I've saved of fairly original 2nd Gens, noticed that the 4 screws holding the glovebox lid to the dash on the inside as it closes, vary a fair amount.
All are blackened, a few have what appears to be the same phillips-head screws as the glovebox liner uses. Other use similar but with small captive washer under the head.
Then there's the similar alternative but using a hex head screw only, or again, with a captive washer under the head.
What's yours have that you believe is original?
Old 07-04-2021, 01:29 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
As I recall......Van Nuys builds used a black (phosphate) phillips button head with a small washer face....
Don't recall seeing hex head screws there ever....Prolly a previous owner hack?
Old 07-04-2021, 02:07 PM
highway star's Avatar
highway star highway star is offline
I concur with green hornet, same on my ‘78 Van Nuys T/A.
Old 07-04-2021, 02:51 PM
As I recall....The glovebox liners used the same phillips head screw...till 77 or 78.....Then they went to 7mmm hex...( I HATE metric bolts)..
Old 07-04-2021, 05:04 PM
burd burd is offline
Hex head. Mines orig stuff.
Old 07-05-2021, 09:25 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Phillips on my 78 and pretty sure my 81.
Skip Fix
Old 07-05-2021, 09:45 AM
Thanks Guys, still a variation with no particular pattern.
