The car is in the shop getting it's TKX swap. What crossmember works? It currently has an aftermarket unit designed to work with the overdrive transmission that was installed.
According to a quick search of the archives, the factory cross member works but a couple of holes need to be drilled.
When I did my TKO, that was also the case.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
Thank you very much I'll get one on order.
