Old 07-10-2021, 09:42 AM
76LQ9TA 76LQ9TA is offline
Default 2nd gen IRS
I've finished installing a new independent rear suspension in a 1981 Trans Am. Tubular DOM upper and lower control arms, fabricated 9" housing with Strange HD aluminum 3rd member, 33 spline CV shafts, Corvette hub assemblies. Bilstein triple adjust coilover shocks and Wilwood Corvette brakes. Also installed tubular subframe connectors and a new front subframe. The front spindles use C5 Corvette hub assemblies. The rear will fit 335 width tires and the front 315 width. The rear suspension is all bolt in. I have just over 4" of ground clearance. The exhaust is 3" stainless and exits through factory looking splitters.
ID:	569511   Click image for larger version
ID:	569512   Click image for larger version
ID:	569513   Click image for larger version
ID:	569514   Click image for larger version
The Following User Says Thank You to 76LQ9TA For This Useful Post:
Old 07-10-2021, 09:44 AM
more pics
ID:	569516   Click image for larger version
Old 07-10-2021, 10:05 AM
Formula8's Avatar
Formula8 Formula8 is offline
Nice work! You will have to bring it by when you get it back home!
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 07-10-2021, 12:43 PM
1965gp 1965gp is offline
Fantastic job installing/ fabricating
Old 07-11-2021, 02:44 PM
cnc's Avatar
cnc cnc is offline
How was the subframe installed….guide pins in the locating holes and measure from the outer edge of the rail to the pinch weld at the rocker and square it up….best possible…or specific points of measuring…..looks like some nice stuff….beautiful job….kudos
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 07-11-2021, 02:45 PM
65madgoat's Avatar
So jealous. Great work!
Old 07-11-2021, 03:19 PM
firechicken's Avatar
firechicken firechicken is offline
Wow! That is very cool.
Old 07-11-2021, 03:23 PM
The definition of Suspension Tech.
Owner fabricated or ?
Either way exactly the upgrade that will take these cars to the next level.
Old 07-11-2021, 05:08 PM
Same as installing a factory subframe. Bolt it in and take measurements to make sure it is square.
Old 07-11-2021, 11:17 PM
Formula8's Avatar
I believe it is this: https://www.heidts.com/part/1974-1981-camaro-pro-g-irs/
Old 07-14-2021, 10:45 AM
That's the old design. This one is improved.
The rear has more suspension travel, improved camber gain. easier alignment along with rear toe adjustment and the nominal ride height is adjustable.
The front suspension has new spindles available with -1/2" drop or -1-3/4" drop. These utilize a newly designed C5 Corvette hub assembly that is based off the C5R. Alignment is simplified with the adjusters in the upper control arms. 315 width tires can be used in the front. 18" diameter rims are recommended. Any of the C5 or C6 Corvette brake kits can be used.
The engine has been moved rearward allowing for better weight distribution. The entire 3" exhaust has been assembled to allow as much ground clearance as possible. There's just over 4" of clearance. The headers and mufflers are from StainlessWorks. Oval tubing was used under the 9" housing. The exhaust exits through Pypes original type splitters. V-band clamps were used at the headers to allow the entire exhaust to be removed easily.
The Following 2 Users Say Thank You to 76LQ9TA For This Useful Post:
