Old 07-14-2021, 07:54 PM
Half-Inch Stud's Avatar
Question Who drives a 455 withFlattops and Iron Ram Air Heads?
Working my Spare 455 +030, and have flattops and "48s".
BOP 1-piece Rear Seal in, Forger 4.21" Stroke, 3.25" Mains TQ'd with Factory Bolts. 1973 2-Bolt Block.
Wondering what Octane is needed to drive on the Street THESE DAYS.
Old 07-14-2021, 08:29 PM
Dragncar Dragncar is offline
You can't run flat tops, 4.21 stroke with 48s on pump gas. Never going to work.
I would not push it past 9.5-1 static on 91 octane.
Even back in 1970 with PMD 455s with 64 heads, 10-1 CR the dealerships were getting come backs from customers breaking pistons not running premium fuel. Not sure what the octane rating on premium was back in 1970 but I bet it was higher than 91-93.
Whatever you do, get a custom pump gas cam to give your engine a chance of living.
Old 07-14-2021, 11:21 PM
Formulas's Avatar
Formulas Formulas is offline
Do you have a local source for E85 might be a way to go in a more economical fashion
Old 07-15-2021, 12:37 AM
72projectbird's Avatar
Not the exact same setup, but I had a .060 over 455 with 62 heads and flat tops. Ran on 93, but was right at the edge of not being happy.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-15-2021, 03:20 AM
Brian Baker's Avatar
I've run as much as 10.1:1 with a 4.25" crank and 4.181" bore using 6X heads but you gotta' stay on top of the tune to run 92 octane with it. There's no setting the timing and adjusting the carb and then forgetting about it for a couple of months.
The Following User Says Thank You to Brian Baker For This Useful Post:
Old 07-15-2021, 05:19 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Back in the day, I ran a 455 with 62 heads. 230 cam. 225 cyl press. That thing was not happy at all unless you ran race gas or 100LL that I got from the airport.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 07-15-2021, 05:32 AM
Find some 96s and let it be happy.
Looks like a few guys ran 62s and had issues. They are about 5cc larger than 48s. 48s, zero chance.
Thing is, if you push it all that has to happen is a bad load of gas or a real hot day and you have a blown head gasket or worse.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 07-15-2021, 07:18 AM
All of the above make sense, and the most relevant tells me it is harderin 2021 to ride the combo ping-free bubble than it was in the early 90s.
See here's the thing; sold my 5Cs to a fella (oh he's happy), and only have the 48s andflattops. Flattops are part of a Crank balance.
So, i need 7M5, 4x, 5C, 6X or E or KRE, or Speedmaster to make a "Combo". Well, i hate to bare the 48s to dress up the low compression iron. Speedmaster?...! roundports?
Thinking to build the high-compression deal, break-in cam and rings, then remove the Top-end 48s For Sale as ported and fresh running set of heads, to recoup the low compression set.
Old 07-15-2021, 10:23 AM
Jay S's Avatar
Jay S Jay S is offline
Just my opinion. But if I have a set of high compression heads and spent a bunch of time and money on with port work, valves, guides , ect….I would take a hard look at cutting a symmetrical dish in the flat tops to drop the compression some and run the 48s over starting over again on some lower compression heads. If it is a balanced rotating assembly I would figure the mass loss from the dish and figure the effects on balancing, might be ok yet. That or buy appropriate pistons and maybe sell those pistons and get some pistons that will put the compression in a range that works better. I don’t like doing things twice but I would rather do that than start on another set of heads. Here it is $170 to rebalance, that won’t go very far rebuilding heads, let alone port work, even if it is a DIY scenario. Our best pump gas results (so far) have been with symmetrical dished pistons over flat tops, D shape, or domes. Maybe more factors at play there though. FWIW
I mostly shoot for between 10 to 11 compression on my cast iron heads with a lot of port work in Pontiacs 450 + cid for 87 to 91 octane. FWIWz…I don’t think I am quite to the point I am at 11:1 for 87. I was looking at the new Progression Ignition distributer that you can modified the timing curve and it connects via blue tooth with a smart phone. I think that is my next step to get to 87 on the 11:1 street engines. But I think I will carry the oem HEI in the trunk, just in case…Lol.
Totally stock d port 455 on 91 octane we have been a 10.4 SCR. Might have ran on 87, never tried it. Cam was big for the head flow, it didn’t run great. It dropped the DCR to low for the RPMs the cam wanted to run, and ran out of head flow. Much better results with port work. All our D ports I run are now are 280 cfm or better with RA 4 ports or bigger. I don’t think a really high compression stock port size will work very good in a 455 on pump gas, would need 93 for sure to keep the cam from out running the heads. My pump gas 461 is a 11:1, the 6x-4 heads flow 291@28”, 224 exh, Bullet SR cam.
Most think that the HP gains are to small from the added compression to be worth the risks, most sensible engine builders won’t go there. I think just the thermal and volumetric efficiency are worth the efforts. But it only takes one thing to be overlooked and you end running more octane than originally planned. I did a cam for a friends 455 the compression was suppose to be 9.8. He wanted fo run on 87. I helped degree the cam in and I noticed the pistons where way down at TDC. Measure it at about .030” down, refigured his compression and it was in the lower 9s. He thought it was a good thing becuase it dropped the compression down, I told him it wasn’t going to work out how he was expecting (bad quench). He is determined to get it to run on 87, been helping him on it some. He may get it to run on 87, but it is not there yet. If you get to the point you get a compression target and want to run something by me, shoot me a PM. I enjoy designing high compression pump gas stuff.
The Following User Says Thank You to Jay S For This Useful Post:
Old 07-15-2021, 02:22 PM
opeliac opeliac is offline
When you say "drive it on the street", are you talking about long distance driving? Or just a weekend toy?
How much compression have you figured it'll have?
Old 07-15-2021, 03:57 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
A buddy with 48s on a 428 short block WHEN the head gaskets held ran good. Cranking pressure way in the 200s!
Skip Fix
Old 07-15-2021, 04:35 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Jay,
What (big)cam would allow HIS's combo to work???
From reading here. most 455 pistons are very close to flush???
I have some big chambered 4X's and a set of 7M5's. Only keeping them for cores.
If you and the canned ham get in my neighborhood???
Shut it off
Shut it off
Old 07-15-2021, 04:58 PM
I'm not worried about picking a cam. Cam worry is break-in and run long highways with all the lobes.
TWO headgaskets have crossed my mind, but the squish zone is like 80 mil at TDC.
We got the canned ham to east OK last year and went South to TX and back to Huntsville. Nice trip but a bust for property ideas.
Low compr heads are nearby (surely but condition is hobo old).
Think my running Low-Compr engine ends up in a 95 Lincoln for Tow-travel, IF the spare 455 build can run in the GTO with pump gas. Again the TWO headgasket deal is tempting.
Old 07-15-2021, 06:31 PM
grandam1979 grandam1979 is offline
You can’t get it under 11:1 with those parts if you wanted to mill 20cc dish in pistons but you don’t want to affect your balance job. I did a calculation with .052 head gaskets and it was still over 11:1. Some street cars run 110 just can’t get to far from home
Old 07-15-2021, 09:09 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I'm not sure it will be ok. My experience is wifh a 428 using 62 heads. it needed something to boost the octane up once the motor was warmed up. If i could keep the temps in the 160-170 range i didnt hear it detonating.
Old 07-15-2021, 09:34 PM
FrankieT/A's Avatar
6X-4's is the way to go...
The Following User Says Thank You to FrankieT/A For This Useful Post:
Old 07-15-2021, 09:36 PM
This.
Detach yourself from the #48 heads.
Pump gas operation will be all but guaranteed.
Old 07-15-2021, 09:39 PM
Red face
Piston are Light as possible already, so no ability to dish. Doubled Head gaskets are more practical, or 98-117 cc heads.
Barely any top landing to consider; Eyebrows break into ring lands as it is. Seems i'm stuck with a flattop shortblock.
So it seems i gotta get 7M5, 4X, 5C, 6X 87 cc E-heads, Speedmonsters?, and be done.
Old 07-15-2021, 10:46 PM
Jay S's Avatar
What your wanting to do is making more sense to me now, I figured you had a set of oem style forged speedpro’s. Your right, looking at the webbing reinforcements those pistons don’t look very thick up top for much of a dish, for sure nothing that will get the SCR where it needs to be.
To run thick gaskets I have used Cometic’s. I have went .14” thick. They sell them thick, but it is really not any more expensive to take them apart and “build” your own thickness, which is the same as what Cometic does. Lately it is a ton easier to find thinner gaskets and stack them than find the thick gaskets. I attached a picture of some I have. They just have 2 rivets the keep the layers aligned. When I put together the .14” thick set I bought 2 sets of .075” gaskets and used the inner layers from the second set which gets it to .140”. But depending on how you stack them there are many possibilities for thickness. I ran quick SCR calc and came up with a SCR of 9.85 earlier with a .14” thick set. Which is a long ways from the 12+ SCR that a .045” gasket would end up. But I thought you had SP pistons at the time. IRC, Cometic also sells thick intake gaskets to line the intake back up for the thicker gaskets. I believe that is what I used on the .140” thick set I did. Was kind of expensive but you can take layers out if you want and reuse all the gaskets down the road, or remove some layers and end up with more typical thickness’s if you change direction later.
I have seen some guys get smoking deals on nicely ported d ports too, may get lucky and get one the cc’s that your looking for. Seen a couple guys score some CNC ported sets by SD performance that were trade in’s. One was a nice set of 260 cfm CNC’d 6x-4s for IRC, $400. If you could find something like that moving away from the 48s would be a no brainer.
For sure it would take a heck of a big cam to manage pump gas @ 12 scr in a 455. Makes my brain hurt.
Old 07-16-2021, 06:50 AM
Alot there, thanks. My running engine has 38cc dish (Ross blower pistons) and figured 9.0:1 which is too low. Idles barely good enough but the rest of the performance is quite good, along with low 12s on 89. 87 on the street all day.
I really wonder about compromising the quench with two head gaskets for mid/high 9s:1 Compr and having the quench gap go from .040 to .080 with Flattops and Ram III quench surface. Just has to be on par/better than the quench left from the diameter of a 38cc dish.
And you are correct about the DIY sweat equity into the 48s; also they were pulled when running low-12s, and owned since ~1984
@ Jay S; yes, the Cometics are the get outta jail for fee. What can you say about "performance" with .140" thick head gaskets?
