1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 07-15-2021, 10:10 AM
jpg69bird jpg69bird is offline
Default 16" Wheel Paint Codes
Does anyone know the paint code for the inside of these late 80's wheels?
Is the polished surface just clear coated, or is that painted with some other finish?
Thanks.
Name:	Silver Turbo 16's.jpg
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold
72 GP, 400 Auto - Sold
09 G8 GXP M6 Orig Owner - Sold
76 Trans Am 455, 4 Speed - Current
Old 07-16-2021, 09:06 AM
TAKerry TAKerry is offline
Those are the same wheels I had on my 85 trans am. No idea on the inner painted area, but unless your are looking for a concours correct the grey colour from the early rally wheels would probably be close enough. For the surface area, its been awhile since I had the car but I would bet somebodys paycheck that the surface was natural with a clear coat. Def not painted.
Old 07-16-2021, 09:14 AM
Thanks TAKerry. Definitely not a concourse restoration, since I am putting these on my 76 Trans Am.
I was most likely going to use the Rally II Gray, unless someone has the correct color. I have leftover paint from a resto on the original Rally II's from this 76.
I figured the machined surface was just clear coated. Nice and easy, just some elbow grease.
