Old 07-28-2021, 05:41 PM
stealthgoat's Avatar
stealthgoat stealthgoat is offline
Default Flywheel ring gear damage or something else?
I remember we used to replace OEM flywheel ring gears, is that repair possible for a Centerforce steel ? Flywheel was neutral balanced with rotating assy engine at last build years ago.
Just recently my ministarter is occasionally making grinding noise. The starter is still tight and I can see the shim in place. But in the picture you can see corners of some ring gears have marks, which I don't remember before. Does this look like a engagement / clearance issue, and if so why now?? how bad is this?
May not be related at all, but I have also been fighting a balky clutch / shifter situation (mainly 1st & reverse) for awhile. I think it's shifter adjustment, but I guess it could be clutch or linkage - my jack stands may have shrunk because it's much tighter under the car tinkering with things than it was when I was 25 years younger + 25 lbs lighter ; -)
any ideas ? thanks!
Name:	GTO flywheel .jpg
Tim Baker
1965 GTO Teal Turquoise.
Was stealth black 389 4 barrel 4 speed car.
Now is 428, 400HO #16 heads, Richmond 5spd, 3:08 12 bolt
Old 07-28-2021, 06:58 PM
mgarblik mgarblik is offline
The one picture isn't very good. But from what I can see, you have a starter shim issue. Possibly two issues. Depth to the root of the teeth, {can't see), and full engagement across the teeth. The flywheel damage looks like it could be cleaned-up with a little file and be OK to me. The ring gear it attached to the flywheel somehow, not cut directly on the wheel, so it can probably be replaced. I have had Hays steel flywheel ring gears replaced many times. I have never used or worked on a Centerforce one. IMO, you need to disconnect the battery and gently pry the starter pinion into full contact with the flywheel teeth and gauge where you are. I use a large diameter paperclip, unbend it, they are around .030" wire. You should be able to slide the paperclip under the root of the flywheel tooth with the starter pinion engaged. The pinion should slide across the ring gear tooth most of the way across. It looks like it's not traveling far enough across the flywheel teeth. Most quality starters have a way to shim both conditions. Good luck.
Old 07-28-2021, 09:24 PM
John Milner's Avatar
John Milner John Milner is offline
I have had luck using no shims on my starters with a manual transmission flywheel. I mainly run delco starters and never use shims with those. My mini starter would grind and finally I removed the shims and the grinding noise went away.
Old 07-28-2021, 10:43 PM
Formulajones's Avatar
Originally Posted by stealthgoat View Post
I remember we used to replace OEM flywheel ring gears, is that repair possible for a Centerforce steel ? !
Should be able to. What I've done several times in the past is press the ring gear off and flip it, if the other side is in good shape.
https://youtu.be/XqEydRRRwqE
Old 07-29-2021, 09:40 PM
I appreciate everyone's suggestions. I should have some time this weekend to dig into this a little more. thanks
Tim Baker
Old 08-01-2021, 07:29 PM
weekend update - starter is actually an older IMI-908 HiTorque starter, not standard smaller IMI-108 version. Purchased from Ace Brewer @ Pacific Performance Racing in about 2005, may be overkill for this street car
In my pictures you can the starter pinion gear teeth are also marked up, and the starter / flywheel don't have full engagement. I could maybe clean this up with some file work, but I reached out to IMI to see if they sell a replacement gear kit - haven't heard back yet.
I had switched to Centerforce 30lb steel flywheel when 428 was built, as seemed more 'streetable' than previous aluminum flywheel. So starter was originally set up with flywheel while on the engine stand, and it's much harder to try to measure the clearance / backlash in car while flat on my back - it's tight up there. Also flywheel is neutral balanced to engine, so if I end up replacing flywheel then it looks like McLeod or Hays are best neutral options available?
thanks!
ID:	570711   Click image for larger version
Tim Baker
Old 08-01-2021, 08:09 PM
TransAm400 TransAm400 is offline
Had the same issue with a RobbMc mini starter and an aftermarket flywheel. Not enough engagement on the flywheel. I put a stock starter back in and it has been working fine.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 08-01-2021, 08:10 PM
ID67goat's Avatar
ID67goat ID67goat is offline
thanks!
Had this same exact issue with a Powermaster starter. I ended up replacing the ring gear (although my flywheel is a Hayes) and then going with a RobbMC starter.
Other than the pain of having to pull the transmission etc, replacing the ring gear wasn't too big of a deal. Heated up old ring gear until it expands enough to be removed from the flywheel. Then heat up the new one and drop it over the flywheel and make sure it is fully seated. It would be much cheaper, and impact your balancing less if you go this route.
The RobbMC starter pinion extends further offering better engagement with the flywheel, they also offer a pinion support that helps support the load put on the pinion during cranking. I did rebuild the Powermaster and still have it as a spare...I imagine that IMI should have the parts to fix yours also.
For re-shimming...just check it while you are re-assembling everything...install the flywheel, and then mount the starter to setup the shims before installing the bellhousing etc. Much easier to see that way.
