Old 08-23-2021, 04:42 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Seat Belt Length
I know this was covered here previously.....and I actually did write down the details......but you know how that one goes....
Tried a couple of searches....but it didn't come up...
I'm sorting my seatbelts...and have found 3 or more different lengths of female and male end belts..and some of them may have been robbed from A and B bodys...but need to know correct lengths for 70-73 F-cars.....Thanks
Old 08-23-2021, 06:23 PM
What year?
Have 1970, 1971, & late 72 production standard F-body belts I can check.
Looking for an Irvin drivers side front retractor assembly for a late model 72 F-body.
(Don't care what color the thin flexible plastic molded cover is as long as the cover is not torn)
Old 08-23-2021, 08:34 PM
71 / early 72 should be the same....
Not many of the later style seen around here...
Old 08-27-2021, 02:29 PM
unruhjonny's Avatar
FYI:
the only difference between 1970 & 1971/early-1972 are the drivers side "male" parts;
1970 it was a retracting belt, while the other was a fixed length in a plastic sleeve.
I believe that the following belts all have unique lengths:
  • 70-72* front "female" belts (same length for shoulder and lap belts)
  • 70-72* front "male" shoulder belts
  • 70-72* rear "female" belts
  • 70-72* rear "male" belts
Now I have never seen them in person, but I have understood that the optional rear shoulder belts may have been the same as the front shoulder belts - I do not know if the "female" end of rear shoulder belt was the same as the front or rear "female" belt.
1970 Formula 400
Old 08-27-2021, 08:12 PM
Originally Posted by unruhjonny View Post
FYI:
As I recall.....the front female/buckle ends are different lengths...
Old 08-27-2021, 10:29 PM
Measured a '71/early '72 front seat male lap belt.
From the very bottom of the plastic "stalk" to the very top of the plated male end: 20 1/4"
On the female belts laying against the passenger bucket seat, one is indeed 4-5" longer than the other. Will investigate further in the AM, am going to have to get up in the mezzanine & pull out some boxed sets.
Old 09-02-2021, 08:45 AM
SD455DJ SD455DJ is offline
GH, Here is a picture of the original upper shoulder belt in my '70 Formula, so you can measure from the mounting point to the bottom of the rear seat cushion for overall length.
Dennis
Old 11-21-2021, 07:35 PM
RLEngland RLEngland is offline
Default 1970 Firebird Seat Belt Info
1970 Firebird/Trans Am/Camaro Blue Seat Belts
Front Seats:
IRVIN Model # 2004, 15A70, 22" (Retractor)
IRVIN Model # 2004, 12A70, 30" (wo/buckle)
Shoulder Harness:
IRVIN Model # 2050, 13A70, 36" (w/buckle)
IRVIN Model # 2050, 13A70, 29" (wo/buckle)
Rear Seats:
IRVIN Model # 2910, 9A70, 32" (wo/buckle)
IRVIN Model # 2910, ?, 15" (w/buckle)
The Following User Says Thank You to RLEngland For This Useful Post:
Old 11-24-2021, 09:09 PM
Thanks...for everybodys input on this...
