Old 08-25-2021, 09:40 PM
kalvert's Avatar
kalvert kalvert is offline
Default Simple Bluetooth setup without destroying dash
Thought I would share my new little setup…
Old 08-25-2021, 10:12 PM
kalvert's Avatar
No modifications to factory wiring, radio, or reverb… front speaker will still function with factory radio at anytime. Rear seat speaker will be utilized with this amp but with separate wiring.
Old 08-26-2021, 12:04 AM
Stuart's Avatar
Stuart Stuart is offline
Make sure the impedance of the speaker is compatible with the amplifier.
Old 08-26-2021, 12:41 AM
bhill86's Avatar
bhill86 bhill86 is offline
I actually have that amp in my 77 T/A. And if you wanted to, you could actually run the radio through the amp utilizing a modern (4ohm) speaker if you wanted. I don’t know enough about a reverb to say whether that could still be utilized but I have 2 4 ohm 6x9s in my rear package tray and a 4 ohm “dual coil” stereo speaker in the factory location. My original AM/FM stereo and console 8 track feed into the amp using a line-in converter which allows them to be utilized with the “modern” speakers then of course switching to Bluetooth allows the amp to take over and feed the “modern” speakers as well.
