Old 09-05-2021, 01:54 AM
Default Light acceleration misfire?
My 440 runs quite well except for two issues: horrifying mileage and a misfire under light acceleration. They may be intertwined.
The 440 is a KRE 85cc headed 400 with 4" stroke and 0.065 overbore.
Mild roller cam with Edelbrock ProFlow 4 fuel injection. I suspect electrical gremlins, perhaps coil? Engine idles rock steady - though timing varies 2-3 degrees, not sure if this is due to a mediocre timing light or other issue.
Old 09-05-2021, 02:40 AM
Schurkey Schurkey is offline
Light acceleration misfire? First thing that occurs to me is excess spark advance.
Of course lean fuel mix including a vacuum leak into one or more cylinders could be a factor.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 09-05-2021, 03:55 AM
lust4speed's Avatar
Agree. I would guess that the misfire is caused by too much vacuum advance under light throttle. Would suspect that slowly bringing the engine revs up in neutral probably will cause the same misfire.
Mick Batson
Old 09-05-2021, 06:21 AM
62posbonny 62posbonny is offline
I am working on fine tuning a pro flo 4 as well. What are your settings for cruise and accel AFR targets? What are your timing settings for idle spark, advance start, total spark and vacuum advance? What is your IAC % at idle when fully warmed up?
So far, I am very impressed at the drivability of the system and have found that fine tuning my spark tables has paid off the most in gettting a very smooth and effortless accelleration at mild throttle. My only issue is a surge at 65-70mph that equates to 2700-3000rpm in my car. Pretty confident with some more seat time I will get that ironed out too.
Old 09-05-2021, 06:22 AM
punkin punkin is offline
I had similar where under light load I was getting misfire chased it for weeks and turned out to be plug wires.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
Northwind (Induction undetermined)
3.50:1 Rear
The Following User Says Thank You to punkin For This Useful Post:
Old 09-05-2021, 06:56 AM
steve25 steve25 is online now
If your hearing the misfire out the exh then it’s most likely a tuning issue or you could even have the firing order wrong.
If the misfire is causing popping back thru the Carb then you may have a intake valve set too tight.
If all was fine and this issue just started after doing something to the motor, then it’s related to that last thing you did more then not!
Old 09-05-2021, 09:40 AM
shaker455's Avatar
shaker455 shaker455 is offline
Start with a compression test
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 09-05-2021, 10:03 AM
Tom Vaught's Avatar
Boost Engineer
X2
Tom V.
Old 09-05-2021, 12:35 PM
That has been my thinking on this, something electrical.
When the misfire occurs you can barely hear it in the exhaust.
I did examine the firing order - it is correct.
So far, I am very impressed at the drivability of the system and have found that fine tuning my spark tables has paid off the most in getting a very smooth and effortless acceleration at mild throttle. My only issue is a surge at 65-70mph that equates to 2700-3000rpm in my car. Pretty confident with some more seat time I will get that ironed out too.
This will take some learning! I plan this morning to change out the cap and reroute the plug wires, especially numbers 5 and 7 and see what shakes out. If that does not work then I will examine the spark curve. It will take a bit to learn this.
I did this earlier - thought I had a leak in #7 intake. Pulled the heads and machine shop pronounced them excellent.
Old 09-05-2021, 01:19 PM
george kujanski's Avatar
For me in the past it was ignition related. i have had it with fouled plugs, poor wires.
When a plug goes to fire, the coil output builds up to the point when the mix ionizes, then discharges thru the spark. As the mixture density increases, (more throttle) , the voltage has to build higher (to the limits of the coil) to the point where the mixture ionizes and the spark discharges.
At the increased voltage, poor plugs and wiring start to show up.
George
Old 09-05-2021, 04:35 PM
I started this morning with the task - clear eyed and open minded. Pulled off the driver's side wires and then went to pull off the passenger side when I noticed this:
https://youtu.be/H8Qx8-C_ZAI
WTF? Is the cap loose? I removed the remaining wires then the cap.
Distributor still moved. Mnnh.
I noted the middle bowl moved while the lower housing remained secure. Pulling the dizzy revealed all 4 upper bolts (red arrow) were loose enough to allow slippage. No lock washers nor locking fluid evident. Green arrow holds upper bowl.
Thanks Edelbrock
Pulled the shaft and removed the screws one at a time, adding a drop of Locktite and resecured. Reassembled the distributor, reinstalled, set timing and road testing shows that this was most likely the issue.
62posbonny: tune map I am using is #2019; pretty mild. Will examine advance curves and fuel more in the future as I am sure this can run much smoother.
I wonder if there is a group that does this with Pontiac V8's only?
Name:	EDDY dizzy internal.jpg
Old 09-05-2021, 06:44 PM
Scott65's Avatar
Scott65 Scott65 is offline
Glad you found the problem! Makes me glad again that I went with a crank mounted trigger wheel.
'65 Tempest 467 3650# [email protected]
Old 05-31-2025, 04:09 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
Default Pro Flo 4
Thanks Edelbrock
Searching the web found me your post. I have a 461 Kauffman, 310 heads and pro flo 4. I also noticed when setting the base timing, it too would bounce around when using a timing light. Then I saw you had found loose hardware inside the distributor, did this end up solving your issue? Curious what timing settings you have. I'm at 17.25 base, starting @1200. 36 max at 3000 rpm and 10 degrees of vacuum advance.
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
Old 05-31-2025, 04:48 PM
If that’s Dizzy was made in China I am not the least bit surprised there was loose screws!
With what I do for part of my daily QC and repair work gear, stuff from China comes in two different ways.
Either bolts and screws did not get tightened down enough, or they where made so dam tight that it stretched out the fastener and near strips out the hole when you apply enough force to remove the fastener.
Old 05-31-2025, 05:11 PM
gassman_67's Avatar
Default Dizzy
Guess I'm pulling it out to check. Thanks for the quick response
552HP 594 TQ
Old 05-31-2025, 05:34 PM
gassman_67's Avatar
Maybe that's why even though I set max timing at 36, I've seen it go to 40, something must be loose inside
552HP 594 TQ
