Need some expertise.
The trunk on my 64 is bound up tight and won't open. Have tried driving around, WD40 in the key cylinder, pressure on the deck, etc. etc. etc. Nothing works. An ideas short of crawling in thru the trunk? Thanks, Rick
Good luck on trying to crawl thru the trunk. MAYBE in a convertible if you trash the cloth pocket that the top folds down into and you have put the top up.
Tom V.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
Got it, upward pressure
Thanks Tom
Does the key turn?
Chris, it would turn but not far enough to unlock. It;s working now.
| The Following User Says Thank You to Koppster For This Useful Post: | ||
I dip my keys and work all locks a couple of times a season to keep everything sliding as it should.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
| The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
