73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 09-11-2021, 08:09 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default 77 base lemans gauge size
Does anyone know the size of fuel oil and temp gauge on the 73 gto rally cluster the 3 gauge not the six gauge
Sent from my SM-S506DL using Tapatalk
Old 09-14-2021, 08:42 AM
77 Canamman's Avatar
The instruments are the same size as the same era F body. The two larger pods are 4 1/2" and the small one is 2 1/16". Do a search in the F body forums for aftermarket gauges that fit the stock openings. The downside to the A body dash versus the F body dash is there are fewer places in the dash cluster to mounts all of the aftermarket gauges you will need. That's why the OEM Rally cluster jammed the oil pressure, fuel, and temp in the center pod, and deleted the voltmeter in favor of the GEN lamp in the tach/clock.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
