Old 09-13-2021, 09:30 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
Default brake and fuel line clips
i see on ebay kits stating red as original color. i just stripped a frame and they were a light green color whats correct
Old 09-14-2021, 08:53 AM
burd's Avatar
burd burd is offline
Inline sells some, but those guys are usually wrong
Old 09-14-2021, 10:06 AM
'72, what make/model did you strip down to the frame?
Old 09-14-2021, 11:30 AM
John V. John V. is offline
My '64 GTO convertible frame pretty sure I noticed green clips on original lines.
I can't recall if I noticed them on the brake lines or fuel lines or both. I kept the original lines and might have the clips still on them. I'll try to check soon.
IIRC, the repro clips that were used for the resto were some red and some green. Again, I don't recall which were which.
I "assumed" they were "correct" but didn't get too anal about it.
I'll be curious what other opinions say about it.
Mine was built at Fremont in Nov. '63 FWIW.
Old 09-14-2021, 08:24 PM
72pontiac's Avatar
actually i stripped 2 gto frames a 64 and a 65
Old 09-14-2021, 09:14 PM
4dblnkldude's Avatar
The right stuff is the cat's ball sack.
Old 06-26-2022, 07:37 PM
72pontiac's Avatar
Well I did the best I could to make the red inline tube ones appear correct
ID:	593358   Click image for larger version
Old 06-26-2022, 07:47 PM
72pontiac's Avatar
I need to be sure of clip orientation.
I believe it is from the back to front fuel line up brake line down then fuel down and brake up on the next 3
