EFI Tech All things EFI and making classics modern!
Old 09-24-2021, 09:06 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Holley EFI Pro 6.8" Dash In My GTO, Steering Wheel Mounting Info
Since more of us will be going fuel injection over the years I figured I'd add how I've mounted the Holley Dash to my steering wheel to make use of all the data.
Holley Dash
https://www.holley.com/products/fuel.../parts/553-112
Bought a mounting bracket that went around the steering column, rubber helps vibration
https://www.holley.com/products/gaug...s/parts/26-621
Got a back panel kit for the dash that completed this
https://quickdrawbrand.com/product/u...6-86-pro-dash/
It's really nice, I'll ditch all the other gauges now.
Picture of dash is without the car running.
I'm monitoring 7 things in that window.....
Brake Vacuum (Hella pump with reservoir)
Trans Temp
MPH (gps)
RPM
Water Temp
Oil
Battery
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 09-25-2021, 02:14 AM
Scott65's Avatar
Scott65 Scott65 is offline
Good work there. Looks like a good display.
'65 Tempest 467 3650# [email protected]
Old 09-25-2021, 12:43 PM
1968GTO421's Avatar
Kinda reminds me of some of the offerings from Dakota Digital. Nice work you did.
Pontiac offerings:
https://www.dakotadigital.com/index....cat/cat413.htm
GTOAA--https://www.gtoaa.org/
Old 09-28-2021, 05:37 PM
nmoreilly nmoreilly is offline
Nice work. I have the 7 inch dash and see that quickdraw makes a back for that one too. Was the Holley steering column bracket easy to attach to the back on yours ?
Old 10-03-2021, 12:38 AM
GOAT8U2's Avatar
It wasn't too hard after I got all the pieces but to start from scratch this took a long time to piece together.
You'll need to get the GPS sensor since you don't see your gauge anymore. Even turn signals aren't gonna be easy to see with this.
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 10-03-2021, 12:51 PM
Very helpful, thanks
